[mapserver-dev] Re: [MapServer] #2664: configure does not work
for fribidi2
Daniel Morissette
dmorissette at mapgears.com
Thu Jul 3 11:42:24 EDT 2008
Thanks guys. That is now fixed in SVN trunk.
Daniel
Alan Boudreault wrote:
> The error (or my error :) ) is located in the configure.in line 1917.
> I wrote:
> $FRIBIDI_PKG_CONFIG = "no"
> instead of
> FRIBIDI_PKG_CONFIG="no"
> Thanks for the bug report!
> Alan
> Stephen Woodbridge wrote:
>> Daniel,
>> Trivial testing looks good. I tried it on a couple of systems and also
>> tried --with-fribidi-config=../fribidi/fribidi.pc which worked fine
>> also.
>> I did get one error below but it seemed to configure and build ok.
>> ./configure: line 11962: =: command not found
>> -Steve
>> ./configure \
>> --enable-ignore-missing-data \
>> --enable-debug \
>> --with-httpd=/usr/sbin/apache \
>> --with-proj=/usr \
>> --with-agg=/u/software/agg-2.4 \
>> --with-fribidi-config=yes \
>> --with-gd \
>> --with-gdal \
>> --with-freetype \
>> --with-postgis \
>> --without-tiff \
>> --with-wmsclient \
>> --with-ogr \
>> --with-wfs \
>> checking if FriBidi support requested... yes
>> checking for fribidi-config... no
>> checking for fribidi pkg-config path... yes
>> yes, user supplied path to fribidi.pc
>> FriBidi support: -DUSE_FRIBIDI -DUSE_FRIBIDI2
>> make
>> ./mapserv -v
>> MapServer version 5.2.0-beta4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS
>> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> -Steve
>>> Daniel,
>>> Awesome! I will jump on beta4 and let you know if I run into any
>>> problems.
>>> -Steve W
>>> MapServer wrote:
>>>> #2664: configure does not work for fribidi2
>>>> Reporter: woodbri | Owner: dmorissette
>>>> Type: defect | Status: assigned
>>>> Priority: normal | Milestone: 5.2 release
>>>> Component: Build Problems | Version: svn-trunk (development)
>>>> Severity: normal | Resolution:
>>>> Keywords: |
>>>> Changes (by dmorissette):
>>>> * status: new => assigned
>>>> * owner: aboudreault => dmorissette
>>>> Comment:
>>>> I have applied the patches in r7771, in time for 5.2.0-beta4.
>>>> Leaving ticket open to add relevant updates to README.CONFIGURE
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
