[mapserver-dev] MapServer build problems on Windows
Yewondwossen Assefa
yassefa at dmsolutions.ca
Thu Jul 3 10:27:06 EDT 2008
This is now fixed in svn (http://trac.osgeo.org/mapserver/ticket/2676).
For those building on windows, beta-4 won't build so you need to either
apply the same modifications as in the bug or build out of svn.
Best Regards,
Daniel Morissette wrote:
> Tamas Szekeres wrote:
>> Hi All,
>> The current version in the SVN trunk doesn't compile, you can see the
>> output at the buildbot:
>> http://buildbot.osgeo.org:8504/builders/szekerest-vc80-full/builds/11/steps/nmake/logs/stdio
> That's probably related to the changes I made for
> http://trac.osgeo.org/mapserver/ticket/2673 yesterday, but I don't
> understand why we get that unresolved _msGettimeofday symbol since it's
> defined for _WIN32 in maptime.c/.h .,.. and it's already been in use in
> other files for a while.
> I'm not setup to build on Windows at the moment, so if someone has an
> idea...
> Daniel
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
