[mapserver-dev] php_mapscript imageObj->saveImage(filename) -broken in beta4?
Jim Klassen Jim.Klassen at ci.stpaul.mn.us
Thu Jul 3 15:46:03 EDT 2008
All,
This may be the same thing but from a different route. For me it shows up w/CGI mapserver on mode=legend with a bitmap legend and Debugging turned on.
I am seeing a seg fault in msSaveImage in maputil.c:643 in beta4 that wasn't in beta2. I think it has something to do with the new msGettimeofday call.
Jim
>>> Daniel Morissette <dmorissette at mapgears.com> 07/03/08 12:45 PM >>>
Man, that's not my day. That's something else I broke with one of my
changes yesterday. Fixing it now:
http://trac.osgeo.org/mapserver/ticket/2677
Daniel
Mike Leahy wrote:
> Hello List,
> I just gave beta 4 a try - it seems something has broken the saveImage
> function in PHP_MapScript in beta4 - but only when the image is saved to
> a filename.  When the image is sent directly to the web browser via
> stdout, the output looks fine.  But if a filename is supplied, no file
> is created, and no errors are generated.  This is with a fresh checkout
> of the beta4 tag in svn.  I've gone back to beta3 and everything is fine
> again - is this a known issue of any sort, or should a new bug be filed?
> Regards,
> Mike
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
