[mapserver-dev] php_mapscript imageObj->saveImage(filename)
-broken in beta4?
Daniel Morissette
dmorissette at mapgears.com
Fri Jul 4 11:05:55 EDT 2008
Jim Klassen wrote:
> All,
> This may be the same thing but from a different route. For me it shows up w/CGI mapserver on mode=legend with a bitmap legend and Debugging turned on.
> I am seeing a seg fault in msSaveImage in maputil.c:643 in beta4 that wasn't in beta2. I think it has something to do with the new msGettimeofday call.
That's very likely the same thing (which is fixed in SVN trunk now BTW).
Are you able to test with the fix and confirm that your problem is also
fixed? If you can't compile yourself then you may have to wait for the
next beta/rc next week.
Daniel
Daniel Morissette
http://www.mapgears.com/
