[mapserver-dev] Legend not shown
SUSANNE
susanne.kalliany at tefis.at
Fri Jul 11 16:04:48 EDT 2008
Thanks a lot for your kind comment.
I do shp2img at same mapfile and get the map as intended.
greetings from Austria, Susanne Kalliany
SUSANNE wrote:
> Hallo,
> I am trying to build a legend for classes 'Bloesse', 'AKL I', ... with
> following command:
> legend "C:\ms4w\Apache\htdocs\ka-map-1.0\TEFprojects\globalPrint.map"
> "C:\ms4w\Apache\htdocs\ka-map-1.0\TEFprojects\legend.png"
> A png image is built, but it is only showing one grey panel.
> Please could somebody give me a hint.
> Thanks a lot for your efforts, Susanne Kalliany
> globalPrint.map:
> MAP NAME global_map
> STATUS ON
> SIZE 1000 700
> EXTENT 45445 329943 47590 331562
> UNITS meters
> IMAGECOLOR 255 255 255
> IMAGETYPE png24
> FONTSET "c:/ms4w/apps/gmap-ms46/etc/fonts.txt"
> SYMBOLSET
> "c:/ms4w/Apache/htdocs/ka-map-1.0/TEFsource/TEFstylesheet/symbols.sym"
> DEBUG ON
> CONFIG "MS_ERRORFILE" "/ms4w/Temp/mapserver.log"
> PROJECTION
> "init=epsg:31282"
> END
> # Symbol symbol-layer or annotation
> SYMBOL
> NAME "poi01" # Bezirkshauptstaedte
> TYPE pixmap
> IMAGE
> "c:/ms4w/Apache/htdocs/ka-map-1.0/TEFsource/TEFicons/poi_01_on.png"
> END
> LEGEND
> KEYSIZE 12 12
> LABEL
> TYPE truetype
> FONT "Arial"
> SIZE 9
> COLOR 0 0 0
> END
> STATUS embed
> POSITION ul
> END
> # Scalebar
> SCALEBAR
> STATUS EMBED
> POSITION lr
> STYLE 0
> INTERVALS 4
> LABEL
> COLOR 0 0 0
> SIZE LARGE
> END
> SIZE 200 3
> TRANSPARENT ON
> COLOR 0 0 0
> BACKGROUNDCOLOR 255 255 255
> OUTLINECOLOR 0 0 0
> UNITS METERS
> END
> LAYER
> NAME zobject1
> GROUP zobject1
> STATUS ON
> MAXSCALE 30000
> TYPE POLYGON
> CONNECTIONTYPE postgis
> CONNECTION 'user=postgres password=susi dbname=tefisdb host=localhost
> port=5432'
> DATA 'the_geom FROM zobject1'
> PROJECTION
> 'init=epsg:31282'
> END
> LABELITEM 'uabt'
> CLASS
> NAME 'Bloesse'
> EXPRESSION ("[akl]"="Bl")
> STYLE
> COLOR 200 200 200
> OUTLINECOLOR 0 0 0
> WIDTH 2
> END
> LABEL
> TYPE TRUETYPE
> FONT 'sans'
> SIZE 10
> POSITION cc
> Color 0 0 0
> END
> END
> TEMPLATE 'dummy.html'
> CLASS
> NAME 'AKL I'
> EXPRESSION ("[akl]"="I")
> STYLE
> COLOR 255 255 0
> OUTLINECOLOR 0 0 0
> WIDTH 2
> END
> LABEL
> TYPE TRUETYPE
> FONT 'sans'
> SIZE 10
> POSITION cc
> Color 0 0 0
> END
> END
> CLASS
> NAME 'AKL II'
> EXPRESSION ("[akl]"="II")
> STYLE
> COLOR 255 0 0
> OUTLINECOLOR 0 0 0
> WIDTH 2
> END
> LABEL
> TYPE TRUETYPE
> FONT 'sans'
> SIZE 10
> POSITION cc
> Color 0 0 0
> END
> END
> CLASS
> NAME 'AKL III'
> EXPRESSION ("[akl]"="III")
> STYLE
> COLOR 100 200 100
> OUTLINECOLOR 0 0 0
> WIDTH 2
> END
> LABEL
> TYPE TRUETYPE
> FONT 'sans'
> SIZE 10
> POSITION cc
> Color 0 0 0
> END
> END
> CLASS
> NAME 'AKL IV'
> EXPRESSION ("[akl]"="IV")
> STYLE
> COLOR 050 150 250
> OUTLINECOLOR 0 0 0
> WIDTH 2
> END
> LABEL
> TYPE TRUETYPE
> FONT 'sans'
> SIZE 10
> POSITION cc
> Color 0 0 0
> END
> END
> END
> END
View this message in context: http://www.nabble.com/Legend-not-shown-tp18400546p18411624.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
