[mapserver-dev] Legend not shown
Steve Lime
Steve.Lime at dnr.state.mn.us
Fri Jul 11 16:11:06 EDT 2008
I've not used 'legend' in ages so perhaps it's simply broken. You could try calling the mapfile
via the CGI with mode=legend and generate the image that way.
Steve
>>> On 7/11/2008 at 3:04 PM, in message <18411624.post at talk.nabble.com>, SUSANNE
<susanne.kalliany at tefis.at> wrote:
> Thanks a lot for your kind comment.
> I do shp2img at same mapfile and get the map as intended.
> greetings from Austria, Susanne Kalliany
> SUSANNE wrote:
>> Hallo,
>> I am trying to build a legend for classes 'Bloesse', 'AKL I', ... with
>> following command:
>> legend "C:\ms4w\Apache\htdocs\ka-map-1.0\TEFprojects\globalPrint.map"
>> "C:\ms4w\Apache\htdocs\ka-map-1.0\TEFprojects\legend.png"
>> A png image is built, but it is only showing one grey panel.
>> Please could somebody give me a hint.
>> Thanks a lot for your efforts, Susanne Kalliany
>> globalPrint.map:
>> MAP NAME global_map
>> STATUS ON
>> SIZE 1000 700
>> EXTENT 45445 329943 47590 331562
>> UNITS meters
>> IMAGECOLOR 255 255 255
>> IMAGETYPE png24
>> FONTSET "c:/ms4w/apps/gmap-ms46/etc/fonts.txt"
>> SYMBOLSET
>> "c:/ms4w/Apache/htdocs/ka-map-1.0/TEFsource/TEFstylesheet/symbols.sym"
>> DEBUG ON
>> CONFIG "MS_ERRORFILE" "/ms4w/Temp/mapserver.log"
>> PROJECTION
>> "init=epsg:31282"
>> END
>> # Symbol symbol-layer or annotation
>> SYMBOL
>> NAME "poi01" # Bezirkshauptstaedte
>> TYPE pixmap
>> IMAGE
>> "c:/ms4w/Apache/htdocs/ka-map-1.0/TEFsource/TEFicons/poi_01_on.png"
>> END
>> LEGEND
>> KEYSIZE 12 12
>> LABEL
>> TYPE truetype
>> FONT "Arial"
>> SIZE 9
>> COLOR 0 0 0
>> END
>> STATUS embed
>> POSITION ul
>> END
>> # Scalebar
>> SCALEBAR
>> STATUS EMBED
>> POSITION lr
>> STYLE 0
>> INTERVALS 4
>> LABEL
>> COLOR 0 0 0
>> SIZE LARGE
>> END
>> SIZE 200 3
>> TRANSPARENT ON
>> COLOR 0 0 0
>> BACKGROUNDCOLOR 255 255 255
>> OUTLINECOLOR 0 0 0
>> UNITS METERS
>> END
>> LAYER
>> NAME zobject1
>> GROUP zobject1
>> STATUS ON
>> MAXSCALE 30000
>> TYPE POLYGON
>> CONNECTIONTYPE postgis
>> CONNECTION 'user=postgres password=susi dbname=tefisdb host=localhost
>> port=5432'
>> DATA 'the_geom FROM zobject1'
>> PROJECTION
>> 'init=epsg:31282'
>> END
>> LABELITEM 'uabt'
>> CLASS
>> NAME 'Bloesse'
>> EXPRESSION ("[akl]"="Bl")
>> STYLE
>> COLOR 200 200 200
>> OUTLINECOLOR 0 0 0
>> WIDTH 2
>> END
>> LABEL
>> TYPE TRUETYPE
>> FONT 'sans'
>> SIZE 10
>> POSITION cc
>> Color 0 0 0
>> END
>> END
>> TEMPLATE 'dummy.html'
>> CLASS
>> NAME 'AKL I'
>> EXPRESSION ("[akl]"="I")
>> STYLE
>> COLOR 255 255 0
>> OUTLINECOLOR 0 0 0
>> WIDTH 2
>> END
>> LABEL
>> TYPE TRUETYPE
>> FONT 'sans'
>> SIZE 10
>> POSITION cc
>> Color 0 0 0
>> END
>> END
>> CLASS
>> NAME 'AKL II'
>> EXPRESSION ("[akl]"="II")
>> STYLE
>> COLOR 255 0 0
>> OUTLINECOLOR 0 0 0
>> WIDTH 2
>> END
>> LABEL
>> TYPE TRUETYPE
>> FONT 'sans'
>> SIZE 10
>> POSITION cc
>> Color 0 0 0
>> END
>> END
>> CLASS
>> NAME 'AKL III'
>> EXPRESSION ("[akl]"="III")
>> STYLE
>> COLOR 100 200 100
>> OUTLINECOLOR 0 0 0
>> WIDTH 2
>> END
>> LABEL
>> TYPE TRUETYPE
>> FONT 'sans'
>> SIZE 10
>> POSITION cc
>> Color 0 0 0
>> END
>> END
>> CLASS
>> NAME 'AKL IV'
>> EXPRESSION ("[akl]"="IV")
>> STYLE
>> COLOR 050 150 250
>> OUTLINECOLOR 0 0 0
>> WIDTH 2
>> END
>> LABEL
>> TYPE TRUETYPE
>> FONT 'sans'
>> SIZE 10
>> POSITION cc
>> Color 0 0 0
>> END
>> END
>> END
>> END
