[mapserver-dev] how does CONNECTIONTYPE function?
zhox at 163.com
zhox at 163.com
Tue Jul 15 22:26:10 EDT 2008
Hi guys,
I want to know why I meet a problem telling that "getSymbol():Symbol definition error. Parsing error near(LOCAL):(line 91)" when I declare the CONNECTIONTYPE as LOCAL, if I do not declare that, it is OK. Does that mean if I use a shapefile as data source, I can not declare the CONNECTIONTYPE definitely even it has a default value of LOCAL? Following is the affected segment of the Mapfile:
______________________________________________________________________________
LAYER
NAME rivers #shape file
GROUP "VECTOR"
TYPE LINE
STATUS DEFAULT
DATA ../../data/rivers
CONNECTIONTYPE LOCAL
DUMP TRUE
POSTLABELCACHE FALSE
TOLERANCE 5
TEMPLATE "../../templates/rivers_query_body.html"
HEADER "../../templates/rivers_query_header.html"
PROJECTION
"init=epsg:4326"
END
CLASS
NAME "Rivers"
COLOR 0 0 255
END
END
Could you please clarify what's the relationship between CONNECTIONTYPE CONNECTION and DATA?
Enri Zhou
