[mapserver-dev] how does CONNECTIONTYPE function?
Frank Warmerdam
warmerdam at pobox.com
Tue Jul 15 22:43:38 EDT 2008
zhox at 163.com wrote:
> Hi guys,
> I want to know why I meet a problem telling that "getSymbol():Symbol definition
> error. Parsing error near(LOCAL):(line 91)" when I declare the CONNECTIONTYPE
> as LOCAL, if I do not declare that, it is OK. Does that mean if I use a shapefile as
> data source, I can not declare the CONNECTIONTYPE definitely even it has a default
> value of LOCAL? Following is the affected segment of the Mapfile:
> ______________________________________________________________________________
> LAYER
> NAME rivers #shape file
> GROUP "VECTOR"
> TYPE LINE
> STATUS DEFAULT
> DATA ../../data/rivers
> CONNECTIONTYPE LOCAL
> Could you please clarify what's the relationship between CONNECTIONTYPE CONNECTION and DATA?
Enri,
I've never heard of connection type "local" before. Idon't see anything
about it in a grep of the source code. For shapefile layers normally one
does not define CONNECTION or CONNECTIONTYPE - just put the path for the
shapefile in the DATA statement.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
