[mapserver-dev] pg_config detection in configure
Guillaume Sueur guillaume.sueur at neogeo-online.net
Tue Jul 22 07:33:58 EDT 2008
Hi list,
playing around with the new mapserver source, I've found something
annoying into the configure :
when you ask for with-postgis=/some/dir/pg_config, the configure script
finishes ok even if it had warned you that it couldn't find pg_config.
Worse, the final sum up indicates :
PostGIS support:	-DUSE_POSTGIS
making people think it went well.
Actually, there is a message in the middle of configure output, but if
you don't scroll up to check it, you can't know you misconfigured your
path.
Couldn't it stop on this warning, like it does for GD for instance ?
Thanks
Guillaume
