[mapserver-dev] pg_config detection in configure
Daniel Morissette
dmorissette at mapgears.com
Tue Jul 22 08:54:22 EDT 2008
Guillaume,
Could you please file a ticket? I'll take care of it.
Daniel
Guillaume Sueur wrote:
> Hi list,
> playing around with the new mapserver source, I've found something
> annoying into the configure :
> when you ask for with-postgis=/some/dir/pg_config, the configure script
> finishes ok even if it had warned you that it couldn't find pg_config.
> Worse, the final sum up indicates :
> PostGIS support: -DUSE_POSTGIS
> making people think it went well.
> Actually, there is a message in the middle of configure output, but if
> you don't scroll up to check it, you can't know you misconfigured your
> path.
> Couldn't it stop on this warning, like it does for GD for instance ?
> Thanks
Daniel Morissette
http://www.mapgears.com/
