[mapserver-dev] pg_config detection in configure
Paul Ramsey
pramsey at cleverelephant.ca
Tue Jul 22 10:22:09 EDT 2008
Sure, good idea. I'll patch that in as soon as trac login comes back
online and I can put a ticket on it.
Devs: when configure.in is altered, configure presumably is
re-generated. What version of autoconf is recommended for that?
P
On Tue, Jul 22, 2008 at 4:33 AM, Guillaume Sueur
<guillaume.sueur at neogeo-online.net> wrote:
> Hi list,
> playing around with the new mapserver source, I've found something annoying
> into the configure :
> when you ask for with-postgis=/some/dir/pg_config, the configure script
> finishes ok even if it had warned you that it couldn't find pg_config.
> Worse, the final sum up indicates :
> PostGIS support: -DUSE_POSTGIS
> making people think it went well.
> Actually, there is a message in the middle of configure output, but if you
> don't scroll up to check it, you can't know you misconfigured your path.
> Couldn't it stop on this warning, like it does for GD for instance ?
> Thanks
> Guillaume
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
