[mapserver-dev] non spatial tables and WFS
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Jul 28 15:58:44 EDT 2008
I guess if someone is really gung ho on this topic then an RFC is in order...
Steve
>>> On 7/25/2008 at 2:03 PM, in message <488A239F.3070105 at mapgears.com>, Daniel
Morissette <dmorissette at mapgears.com> wrote:
> I'm not sure what to think... part of me thinks this is an abuse of WFS
> (WFS without an 'F'), but then if others (e.g. GeoServer) have done it
> and set a precedent then we may have to do it as well now. At least if
> we do it let's make sure we behave the same way as others with respect
> to things not defined in the WFS spec like what to do with filters vs
> data with no georef.
> Daniel
> Kralidis,Tom [Burlington] wrote:
>> Bart: agreed. I think this would be a good addition to MapServer. What do
> others think of this concept?
>> ..Tom
>> -----Original Message-----
>> From: mapserver-dev-bounces at lists.osgeo.org on behalf of Bart van den Eijnden
> (OSGIS)
>> Sent: Fri 25-Jul-08 13:28
>> To: Steve Lime
>> Cc: Kralidis,Tom [Burlington]; mapserver-dev at lists.osgeo.org
>> Subject: Re: [mapserver-dev] non spatial tables and WFS
>> Hey Tom,
>> if a spatial filter is used then we would just return the full
>> dataset/table (so ignore the spatial filter), at least that seems the
>> most logical to me.
>> Best regards,
>> Bart
>> Steve Lime wrote:
>>> I was thinking about this last night and I remembered that is was the query
> piece that gave
>>> me pause earlier. Since JOINs are not applied when rendering or querying one
> couldn't use
>>> those attributes in queries. Maybe that's not a huge deal.
>>> For non-spatial tables we'd almost need a new layer type, "TYPE TABLE" and
> then would need
>>> to behave accordingly.
>>> Steve
>>>>>> On 7/22/2008 at 5:19 PM, in message
>>> <2DC5CCA14756424BBBEE8B4B2E4A682F036CF454 at ecburexch1.ontario.int.ec.gc.ca>,
>>>>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Steve Lime
>>>>> Sent: 22 July, 2008 5:28 PM
>>>>> To: mapserver-dev at lists.osgeo.org; Bart van den Eijnden (OSGIS)
>>>>> Do you mean attribute tables JOINed to spatial data? If so
>>>>> then that would be a relatively easy addition I think. I
>>>>> remember looking into it when much of the gml work was done
>>>>> but I don't recall what stopped me. I believe Tom K. was
>>>>> interested in something similar.
>>>> I agree this would be valuable (esp JOINed). Having said this, what
>>>> would happen if spatial queries are passed against the non-spatial
>>>> dataset? How would this affect advertising the dataset as a FeatureType
>>>> in a WFS, which advertises Filter Capabilities, or which MapServer
>>>> provides many spatial functions.
>>>>> Steve
>>>>>>>> On 7/22/2008 at 2:19 PM, in message
>>>>> <488632DA.706 at osgis.nl>, "Bart
>>>>>>>> van den
>>>>> Eijnden (OSGIS)" <bartvde at osgis.nl> wrote:
>>>>>> Hi list,
>>>>>> one of the features I've been missing in Mapserver WFS is
>>>>> the ability
>>>>>> to serve out non spatial / administrative tables using WFS,
>>>>> something
>>>>>> that Geoserver does support.
>>>>>> Would this be easy to add in Mapserver or not? Are there any known
>>>>>> workarounds that might work out of the box already?
>>>>>> Best regards,
>>>>>> Bart
>>>>> _______________________________________________
>>>>> mapserver-dev mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
