[mapserver-dev] getting a crash that might be 32-64 bit ro build
issue related
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jun 20 18:42:29 EDT 2008
After spending 3 days chasing a problem that is making me nuts, I
thought I would post this much.
It is clearly label related because if we comment out the label block it
works fine.
I have been able to reproduce this in mapserver CGI just a short while
ago. I will try it with 5.2 when I have a chance and let you know what
happens.
Meanwhile, does this back trace look familiar? Thomas? Steve?
Thanks,
-Steve
MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 46912496217952 (LWP 15375)]
0x00002aaaae38ccb1 in agg::rasterizer_cells_aa<agg::cell_aa>::sort_cells ()
from /usr/lib64/extensions/no-debug-non-zts-20020429/php_mapscript.so
(gdb) bt
#0 0x00002aaaae38ccb1 in
#1 0x00002aaaae39c396 in
agg::render_scanlines<agg::rasterizer_scanline_aa<agg::rasterizer_sl_clip<agg::ras_conv_int>
agg::scanline_p8,
agg::renderer_scanline_aa_solid<agg::renderer_base<agg::pixfmt_alpha_blend_rgba<agg::blender_rgba_pre<agg::rgba8,
agg::order_bgra>, mapserv_row_ptr_cache<int>, int> > > > ()
#2 0x00002aaaae39cbb5 in
AGGMapserverRenderer::renderPathSolid<polygon_adaptor> ()
#3 0x00002aaaae386403 in msDrawShadeSymbolAGG () from
#4 0x00002aaaae36ae2b in msDrawLabelCache () from
#5 0x00002aaaae36f827 in msDrawMap () from
#6 0x00002aaaae328309 in php3_ms_map_draw () from
#7 0x00000000005255fb in execute (op_array=0xd88a418) at
/home/steve/work/php-4.4.8/Zend/zend_execute.c:1681
#8 0x000000000050d44b in zend_execute_scripts (type=8, retval=0x0,
file_count=3)
at /home/steve/work/php-4.4.8/Zend/zend.c:939
#9 0x00000000004e06fb in php_execute_script
(primary_file=0x7fff80acb250) at
/home/steve/work/php-4.4.8/main/main.c:1758
#10 0x0000000000529ed2 in main (argc=4, argv=0x7fff80acb398) at
/home/steve/work/php-4.4.8/sapi/cli/php_cli.c:838
