[mapserver-dev] Demo host?
David William Bitner david.bitner at gmail.com
Thu Jun 19 09:35:22 EDT 2008
Steve, I would guess a limited permission user on the PostGIS database
set up at Telascience would be able to be set up that you could
access.
On Wed, Jun 18, 2008 at 11:14 PM, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> I think that will work fine. I was hoping to demo PostGIS <=> MapServer if possible
> but it's not imperative. I was planning to toss the demo in svn and we could use
> /osgeo/mapserver/demo as a default configuration path. I'll work on getting the
> first demo, "Hello World" in place and we can use that to test.
> I appreciate the help!
> Steve
>>>> Frank Warmerdam <warmerdam at pobox.com> 06/18/08 10:12 AM >>>
> Steve Lime wrote:
>> Hi all: As I put together the demo I proposed awhile back it occurs to me
>> that I need a place to host it. The DNR is not appropriate. I like the
>> newest OpenLayers setup that has many simple examples and was going to
>> emulate that although with a thematic groups. Anyone aware of some options
>> with regards to hosting?
> Steve,
> We could setup an area for hosting this on a telascience blade.  Perhaps
> the "upload.osgeo.org" host we already use for creating mapserver nightly
> snapshots.  In fact, you can go ahead and set stuff up now under
> /osgeo/mapserver/demo and we can do a bit of work on the apache config to
> run mapserver.
> We would presumably need to install mapserver.  Perhaps we could use something
> very self contained like FGS.
> Keep in mind that stuff like /osgeo/mapserver is not backed up by default.
> I'd be happy to work with you on this as needed.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
