[mapserver-dev] MS4W packaging was: MapServer 5.2 Beta 3 Available
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Jun 29 15:58:23 EDT 2008
MS4W packaging guys,
When you have a chance to package up 5.2 can you also include fribidi2
support in that. I have clients that interested in using it for Arabic
and you would make a bunch of people very happy if you can add that.
Thanks,
-Steve W
Steve Lime wrote:
> Hi folks: MapServer 5.2 Beta 3 has just been released, albeit one day
> late. The source package is available for download at:
> http://mapserver.gis.umn.edu/download/beta
> The list of changes/fixes since 5.0 can be found at the end this
> message. This is a significant release so we need your help in
> testing. 5.2 should compatible with any 5.0 applications/mapfiles so
> it should be relatively easy for folks to test. Please let us know
> how it goes!
> This is the 3rd, and last, beta release (we hope) and if all goes
> well there will be a release candidate next wek and the final release
> in less than 2 weeks.
> More details can be found in the 5.2 release plan at:
> http://mapserver.gis.umn.edu/development/release_plans/mapserver_5_2/release_plan/
> Steve
> Version 5.2.0-beta3 (2008-06-26): ---------------------------------
> - mapsde.c: processing option added to allow using fully qualified
> names for attributes (#2423).
> - mapsde.c: Test that for an active connection before closing it
> #2498
> - mapdraw.c: Fixed issue where path following labels were not being
> drawn if FORCEd. (#2600)
> - mapshape.c: Applied patch to make the location of tiled data
> relative to the tileindex directory if SHAPEPATH is not set. (#2369)
> - maptemplate.c: Fixed issues in RFC 36 implementation that prevented
> mapscript mapObj->processQueryTemplate() method from working.
> - WMS/WFS: extend warning message (#1396)
> - WFS: Respect units for the DWhitin parameter (#2297)
> - WFS: correct OGC Contains filter (#2306)
> - WMS: set srsName correctly for GetFeatureInfo (#2502)
> - SOS: detect invalid time strings (#2560)
> - SOS: more srsName support (#2558)
> - mapserv.c, maptemplate.c: fixed problem with arguments to
> msGenerateImages(). (#2655)
> - WMS: produce warning if layer extent is null (#1396)
> - WFS: project LatLongBoundingBox if required (#2579)
> - SOS: generate error for some invalid filters (#2604)
> - SLD: Use style's width paramater when generating sld (#1192)
> _______________________________________________ mapserver-users
> mailing list mapserver-users at lists.osgeo.org
