[mapserver-dev] Proposed maporaclespatial.c header...
Daniel Morissette dmorissette at mapgears.com
Fri Mar 14 13:15:37 EDT 2008
I'm +1 on both the license/header and the filename change.
... and thanks to the authors for their collaboration in the resolution
of this one.
Daniel
Steve Lime wrote:
> Based on conversations with the two principal authors of that code we have received permission to change the header and implied
> licensing in that code. Rodrigo also has said to remove the copyright statements currently in place although I didn't see explict
> copyright statements. That would leave us with what I've pasted below. Does that sit well with all concerned?
> Also, any objection to renaming that file to mapsdo.c?
> Steve
>  * TODO: need appropriate header stuff here...
>  * Project: MapServer
>  * Purpose: Native access to Oracle Spatial (SDO) data.
>  * Author:  Fernando Simon (fsimon at univali.br)
>  *          Rodrigo Becke Cabral
>  *          Adriana Gomes Alves
>  * Notes: Developed under several funding agreements:
>  *   1) n.45/00 between CTTMAR/UNIVALI (www.cttmar.univali.br)
>  *      and CEPSUL/IBAMA (www.ibama.gov.br)
>  *   2) CNPq (www.cnpq.br) under process 401263.03-7
>  *   3) FUNCITEC (www.funcitec.rct-sc.br) under process FCTP1523-031
>  * Copyright (c) 1996-2008 Regents of the University of Minnesota.
>  * Permission is hereby granted, free of charge, to any person obtaining a
>  * copy of this software and associated documentation files (the "Software"),
>  * to deal in the Software without restriction, including without limitation
>  * the rights to use, copy, modify, merge, publish, distribute, sublicense,
>  * and/or sell copies of the Software, and to permit persons to whom the
>  * Software is furnished to do so, subject to the following conditions:
>  * The above copyright notice and this permission notice shall be included in
>  * all copies of this Software or works derived from this Software.
>  * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
>  * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
>  * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
>  * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
>  * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
>  * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
>  * DEALINGS IN THE SOFTWARE.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
