[mapserver-dev] Proposed maporaclespatial.c header...
Steve Lime
Steve.Lime at dnr.state.mn.us
Fri Mar 14 14:32:39 EDT 2008
I'm +1 as well. I'd also want to change OracleSpatial to SDO in the version output and build
parameters (e.g. USE_SDO) as well.
Steve
>>> On 3/14/2008 at 12:15 PM, in message <47DAB2B9.20108 at mapgears.com>, Daniel
Morissette <dmorissette at mapgears.com> wrote:
> I'm +1 on both the license/header and the filename change.
> ... and thanks to the authors for their collaboration in the resolution
> of this one.
> Daniel
> Steve Lime wrote:
>> Based on conversations with the two principal authors of that code we have
> received permission to change the header and implied
>> licensing in that code. Rodrigo also has said to remove the copyright
> statements currently in place although I didn't see explict
>> copyright statements. That would leave us with what I've pasted below. Does
> that sit well with all concerned?
>> Also, any objection to renaming that file to mapsdo.c?
>> Steve
>> * TODO: need appropriate header stuff here...
>> * Project: MapServer
>> * Purpose: Native access to Oracle Spatial (SDO) data.
>> * Author: Fernando Simon (fsimon at univali.br)
>> * Rodrigo Becke Cabral
>> * Adriana Gomes Alves
>> * Notes: Developed under several funding agreements:
>> * 1) n.45/00 between CTTMAR/UNIVALI (www.cttmar.univali.br)
>> * and CEPSUL/IBAMA (www.ibama.gov.br)
>> * 2) CNPq (www.cnpq.br) under process 401263.03-7
>> * 3) FUNCITEC (www.funcitec.rct-sc.br) under process FCTP1523-031
>> * Copyright (c) 1996-2008 Regents of the University of Minnesota.
>> * Permission is hereby granted, free of charge, to any person obtaining a
>> * copy of this software and associated documentation files (the
> "Software"),
>> * to deal in the Software without restriction, including without limitation
>> * the rights to use, copy, modify, merge, publish, distribute, sublicense,
>> * and/or sell copies of the Software, and to permit persons to whom the
>> * Software is furnished to do so, subject to the following conditions:
>> * The above copyright notice and this permission notice shall be included
> in
>> * all copies of this Software or works derived from this Software.
>> * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
>> * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
> MERCHANTABILITY,
>> * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
>> * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR
> OTHER
>> * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
>> * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
>> * DEALINGS IN THE SOFTWARE.
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
