[mapserver-dev] bug in WFS writer?
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed Mar 19 15:33:42 EDT 2008
Okay, I found it already:
http://trac.osgeo.org/mapserver/changeset/7164
Best regards,
Bart
Bart van den Eijnden (OSGIS) wrote:
> Hey Steve,
> Do you remember the bug number or changeset for that point-in-polygon
> fix? It sounds like it could be the culprit indeed.
> You're right it could be a problem in TatukGIS theoretically, but in
> this case things were checked also in ArcGIS. So it would be strange
> for 2 clients to have it wrong, though still possible.
> Mapserver version: 4.10.2.
> I haven't got the source data as yet (it's in Oracle Spatial), but
> I'll try to get it.
> Thanks.
> Best regards,
> Bart
> Steve Lime wrote:
>> Couple of questions:
>> - how are you defining a "problem", based on TatukGIS's rendering
>> or some other method? I'm not saying there isn't a problem but how do
>> you know it's not a problem with the renderer?
>> - do you have the source data (a shapefile?) available for testing?
>> - what version of MapServer?
>> I recall another bug recently similar to this. It had to do with the
>> MapServer point-in-polygon being indeterminate when a point in one
>> part is on a polygon edge. The function is key to determining inner
>> and outer rings. I thought I fixed it though, at least in SVN. Since
>> a legal polygon can only share 1 vertex with an edge I updated the
>> code to check at least 2 and one more to break the tie if one
>> happened to be on an edge. That worked in any testing I had done.
>> Steve
>>>>> On 3/19/2008 at 1:16 PM, in message <47E15866.2010407 at osgis.nl>,
>>>>> "Bart van den
>> Eijnden (OSGIS)" <bartvde at osgis.nl> wrote:
>>> Hi list,
>>> it seems Mapserver WFS has a problem with geometries having a
>>> (common) point in them which touches the geometry itself. Mapserver
>>> WMS seems to draw these polygons okay.
>>> An example (look for instance at the second and third geometry):
>>> WMS:
>>> http://www.osgis.nl/download/umn/wms.png
>>> WFS in TatukGIS (screendump):
>>> http://www.osgis.nl/download/umn/tatuk.png
>>> WFS xml file:
>>> http://www.osgis.nl/download/umn/wfs.xml
>>> Any ideas what could be causing this? Does this ring a bell to anyone?
>>> Best regards,
>>> Bart
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
