[mapserver-dev] RE: [UMN_MAPSERVER-DEV] Performance transparency
Hallgren, Johan
johan.hallgren at logica.com
Thu Mar 20 06:26:08 EDT 2008
Hello
I have had a question last year related to performance when using transparency. Steve mentioned that there are plans to support feature-level transparency. Do we have any progress at that issue? When can I count on that feature?
/Johan
___________________________________
Johan Hallgren
Logica
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel (och mobil): 023-547 46 (int: +46-2354746)
http://www.logica.se
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Steve Lime
Sent: den 19 december 2007 20:31
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] Performance transparency
Hi Johan: I've never quantified the performance hit but it is certainly expected. Layer-level transparency works like this:
- a temporary image is created to render the transparent layer into, it is initialized to be completely transparent
- rendering proceeds as normal in the temp image
- the temp image is then "merged" into the base image, so for every non-transparent pixel in the temp image alpha blending is done and the base image pixel is modified
- the temporary image is discarded
So, the processing time will increase with 1) image size and 2) vector layer density.
There are plans to support feature-level transparency but it won't work in all cases so layer level transparency will remain an option.
So, the results you are seeing are expected although I can't say if double is too much or not.
Steve
>>> On 12/19/2007 at 8:49 AM, in message
<D93CFEAA72FA764885CC1FDA94A1D89C035462F2 at WMRI000166.corp.wmdata.net>, Hallgren
Johan E <jhhal at WMDATA.COM> wrote:
> Hello Friends
> I a question regarding performance when using a transparent vectorlayer
> on top of a rasterlayer. The output is quite large (1400 * 1000 px) and
> vectordata is a shapefile with polygons.
> When turning the transparency on the vector layer the performance goes
> down quite much. It takes maybe double as long time to produce the map.
> Is there any knowledge about that?
> /Johan
> Johan Hallgren
> WM-data, Logica CMG
> Pelle Bergs backe 3
> johan.e.hallgren at wmdata.com
> <blocked::mailto:johan.e.hallgren at wmdata.com>
> http://www.wmdata.se
> <blocked::https://webaccess.wmdata.com/exchweb/bin/redir.asp?URL=http://
> www.wmdata.se/>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080320/6cd42454/attachment.html
