[mapserver-dev] RFC 24 Changes to mapscript/perl/plmodule.i
Umberto Nicoletti umberto.nicoletti at gmail.com
Thu Mar 20 11:52:24 EDT 2008
It will fail if you attempt to disable WFS services (like I do). The
attached patch fixes the problem.
I've opened issue 2556 and attached a patch there. Please see if it works
Umberto
On Thu, Mar 20, 2008 at 4:23 PM, Yewondwossen Assefa
<yassefa at dmsolutions.ca> wrote:
> I am checking the build now. It builds ok with the following config
>  gcc -c -g -O2 -fPIC -Wall    -DHAVE_VSNPRINTF -DNEED_STRLCAT
>  -DUSE_WMS_LYR -DUSE_WFS_LYR -DUSE_SOS_SVR -DUSE_LIBXML2 -DUSE_CURL
>  -DUSE_WCS_SVR -DUSE_WFS_SVR -DUSE_WMS_SVR    -DUSE_POSTGIS  -DUSE_GDAL
>  -DUSE_OGR   -DUSE_PROJ -DUSE_EPPL  -DUSE_AGG   -DUSE_GD_GIF -DUSE_GD_PNG
> -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW
>  -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB
>  Later,
>  Steve Lime wrote:
>  > Not sure on the build problems (not my fault for a change), so I won't update my
>  > source files for a while. I'll try your patch though, seems like an easy fix. Is the
>  > module name (as defined in mapscript.i) available as an env variable? Or perhaps
>  > we could set it there for all subsequent .i files to use?
>  > Steve
>  >>>> On 3/20/2008 at 3:42 AM, in message
>  > <75b4b93e0803200142m57e1892l6c3d1f2aaa7a93a0 at mail.gmail.com>, "Umberto
>  > Nicoletti" <umberto.nicoletti at gmail.com> wrote:
>  >> I was trying to help you out on this one (see attached patch), but I
>  >> can't compile mapserver:
>  >> unicoletti at ziggy ~/Workspace/eclipse/subversion/sandox/mapserver $make
>  >> gcc -c -O2 -fPIC -Wall     -DHAVE_VSNPRINTF -DNEED_STRLCAT
>  >>  -DUSE_WMS_SVR      -DUSE_GDAL  -DUSE_GEOS  -DUSE_THREAD -DUSE_PROJ
>  >> -DUSE_EPPL     -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
>  >> -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR
>  >> -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB     -I/usr/include
>  >>   -I/usr/include/gdal      -I/usr/include      mapwfs11.c -o
>  >> mapwfs11.o
>  >> In file included from mapwfs11.c:32:
>  >> mapows.h:31: error: expected specifier-qualifier-list before 'rectObj'
>  >> mapows.h:97: error: expected specifier-qualifier-list before 'hashTableObj'
>  >> mapows.h:116: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'int'
>  >> mapows.h:120: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'int'
>  >> mapows.h:121: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'int'
>  >> mapows.h:122: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'char'
>  >> mapows.h:123: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'char'
>  >> mapows.h:124: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'const'
>  >> mapows.h:125: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'const'
>  >> mapows.h:143: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'int'
>  >> mapows.h:144: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'const'
>  >> mapows.h:156: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'const'
>  >> mapows.h:158: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'int'
>  >> mapows.h:162: error: expected ')' before '*' token
>  >> mapows.h:166: error: expected ')' before '*' token
>  >> mapows.h:170: error: expected ')' before '*' token
>  >> mapows.h:174: error: expected ')' before '*' token
>  >> mapows.h:178: error: expected ')' before '*' token
>  >> mapows.h:190: error: expected ')' before '*' token
>  >> mapows.h:193: error: expected ')' before '*' token
>  >> mapows.h:196: error: expected ')' before '*' token
>  >> mapows.h:201: error: expected ')' before '*' token
>  >> mapows.h:206: error: expected ')' before '*' token
>  >> mapows.h:211: error: expected ')' before '*' token
>  >> mapows.h:214: error: expected ')' before '*' token
>  >> mapows.h:219: error: expected ')' before '*' token
>  >> mapows.h:222: error: expected ')' before '*' token
>  >> mapows.h:224: error: expected declaration specifiers or '...' before
>  >> 'mapObj'
>  >> mapows.h:225: error: expected ')' before '*' token
>  >> mapows.h:229: error: expected ')' before '*' token
>  >> mapows.h:230: error: expected ')' before '*' token
>  >> mapows.h:232: error: expected ')' before '*' token
>  >> mapows.h:321: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'int'
>  >> mapows.h:322: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'gmlItemListObj'
>  >> mapows.h:323: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'void'
>  >> mapows.h:324: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'gmlConstantListObj'
>  >> mapows.h:325: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'void'
>  >> mapows.h:326: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'gmlGeometryListObj'
>  >> mapows.h:327: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'void'
>  >> mapows.h:328: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'gmlGroupListObj'
>  >> mapows.h:329: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'void'
>  >> mapows.h:330: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'gmlNamespaceListObj'
>  >> mapows.h:331: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'void'
>  >> mapows.h:335: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'int'
>  >> mapows.h:346: error: expected ')' before '*' token
>  >> mapows.h:347: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'int'
>  >> mapows.h:358: error: expected declaration specifiers or '...' before
>  >> 'mapObj'
>  >> 'layerObj'
>  >> mapows.h:361: warning: 'enum MS_CONNECTION_TYPE' declared inside parameter
>  >> list
>  >> mapows.h:361: warning: its scope is only this definition or
>  >> declaration, which is probably not what you want
>  >> mapows.h:363: error: expected declaration specifiers or '...' before
>  >> 'mapObj'
>  >> 'layerObj'
>  >> mapows.h:364: error: expected declaration specifiers or '...' before
>  >> 'imageObj'
>  >> mapows.h:365: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'char'
>  >> mapows.h:380: error: expected ')' before '*' token
>  >> mapows.h:381: error: expected ')' before '*' token
>  >> mapows.h:384: error: expected ')' before '*' token
>  >> mapows.h:385: error: expected ')' before '*' token
>  >> mapows.h:401: error: expected declaration specifiers or '...' before
>  >> 'mapObj'
>  >> 'layerObj'
>  >> mapows.h:403: error: expected ')' before '*' token
>  >> mapows.h:404: error: expected ')' before '*' token
>  >> mapows.h:406: error: expected ')' before '*' token
>  >> mapows.h:407: error: expected ')' before '*' token
>  >> mapows.h:408: error: expected ')' before '*' token
>  >> mapows.h:409: error: expected ')' before '*' token
>  >> mapows.h:410: error: expected ')' before '*' token
>  >> mapows.h:411: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'char'
>  >> mapows.h:417: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'int'
>  >> mapows.h:418: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'int'
>  >> mapows.h:419: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'int'
>  >> mapows.h:420: error: expected '=', ',', ';', 'asm' or '__attribute__'
>  >> before 'int'
>  >> mapows.h:427: error: expected ')' before '*' token
>  >> mapows.h:435: error: expected ')' before '*' token
>  >> mapwfs11.c:35: error: expected declaration specifiers or '...' before
>  >> string constant
>  >> mapwfs11.c:35: warning: return type defaults to 'int'
>  >> mapwfs11.c: In function 'MS_CVSID':
>  >> mapwfs11.c:35: error: expected '{' at end of input
>  >> make: *** [mapwfs11.o] Error 1
>  >> On Wed, Mar 19, 2008 at 10:34 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>
>  >> wrote:
>  >>> Hi all: I've been beating my head against a configuration problem with Perl
>  >> MapScript today that stems from changes
>  >>>  made for RFC 24. I have multiple version of mapscript installed and it's
>  >> fairly straight forward with Perl to do so, change
>  >>>  1 line in mapscript.i and one in Makefile.PL. Until now that is. In
>  >> plmodule.i there are references to mapscriptc and mapscript
>  >>>  that must also be changed. I can do that and will also update the Perl
>  >> README to reflect that additional step. Before I do
>  >>>  so I was wondering if there were a more portable way to write plmodule.i so
>  >> that it could automatically pick up on name
>  >>>  change for the whole module. I don't how big a problem this is for other
>  >> languages. Thoughts?
>  >>>  Steve
>  >>>  _______________________________________________
>  >>>  mapserver-dev mailing list
>  >>>  mapserver-dev at lists.osgeo.org
>  >>>  http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>  Assefa Yewondwossen
>  Software Analyst
>  Email: assefa at dmsolutions.ca
>  http://www.dmsolutions.ca/
>  Phone: (613) 565-5056 (ext 14)
>  Fax:   (613) 565-0925
