[mapserver-dev] RFC 24 Changes to mapscript/perl/plmodule.i
Umberto Nicoletti
umberto.nicoletti at gmail.com
Thu Mar 20 11:28:33 EDT 2008
On Thu, Mar 20, 2008 at 3:59 PM, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> Not sure on the build problems (not my fault for a change), so I won't update my
> source files for a while.
I wasn't blaming you, Steve, just warning you that the patch is untested...
> I'll try your patch though, seems like an easy fix. Is the
> module name (as defined in mapscript.i) available as an env variable? Or perhaps
> we could set it there for all subsequent .i files to use?
It works like a standard C define, I don't think there is support for
env vars. Can be ovverridden on the command line with -D
Umberto
> Steve
> >>> On 3/20/2008 at 3:42 AM, in message
> <75b4b93e0803200142m57e1892l6c3d1f2aaa7a93a0 at mail.gmail.com>, "Umberto
> Nicoletti" <umberto.nicoletti at gmail.com> wrote:
> > I was trying to help you out on this one (see attached patch), but I
> > can't compile mapserver:
> > unicoletti at ziggy ~/Workspace/eclipse/subversion/sandox/mapserver $make
> > gcc -c -O2 -fPIC -Wall -DHAVE_VSNPRINTF -DNEED_STRLCAT
> > -DUSE_WMS_SVR -DUSE_GDAL -DUSE_GEOS -DUSE_THREAD -DUSE_PROJ
> > -DUSE_EPPL -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
> > -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR
> > -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB -I/usr/include
> > -I/usr/include/gdal -I/usr/include mapwfs11.c -o
> > mapwfs11.o
> > In file included from mapwfs11.c:32:
> > mapows.h:31: error: expected specifier-qualifier-list before 'rectObj'
> > mapows.h:97: error: expected specifier-qualifier-list before 'hashTableObj'
> > mapows.h:116: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'int'
> > mapows.h:120: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'int'
> > mapows.h:121: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'int'
> > mapows.h:122: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'char'
> > mapows.h:123: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'char'
> > mapows.h:124: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'const'
> > mapows.h:125: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'const'
> > mapows.h:143: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'int'
> > mapows.h:144: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'const'
> > mapows.h:156: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'const'
> > mapows.h:158: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'int'
> > mapows.h:162: error: expected ')' before '*' token
> > mapows.h:166: error: expected ')' before '*' token
> > mapows.h:170: error: expected ')' before '*' token
> > mapows.h:174: error: expected ')' before '*' token
> > mapows.h:178: error: expected ')' before '*' token
> > mapows.h:190: error: expected ')' before '*' token
> > mapows.h:193: error: expected ')' before '*' token
> > mapows.h:196: error: expected ')' before '*' token
> > mapows.h:201: error: expected ')' before '*' token
> > mapows.h:206: error: expected ')' before '*' token
> > mapows.h:211: error: expected ')' before '*' token
> > mapows.h:214: error: expected ')' before '*' token
> > mapows.h:219: error: expected ')' before '*' token
> > mapows.h:222: error: expected ')' before '*' token
> > mapows.h:224: error: expected declaration specifiers or '...' before
> > 'mapObj'
> > mapows.h:225: error: expected ')' before '*' token
> > mapows.h:229: error: expected ')' before '*' token
> > mapows.h:230: error: expected ')' before '*' token
> > mapows.h:232: error: expected ')' before '*' token
> > mapows.h:321: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'int'
> > mapows.h:322: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'gmlItemListObj'
> > mapows.h:323: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'void'
> > mapows.h:324: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'gmlConstantListObj'
> > mapows.h:325: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'void'
> > mapows.h:326: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'gmlGeometryListObj'
> > mapows.h:327: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'void'
> > mapows.h:328: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'gmlGroupListObj'
> > mapows.h:329: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'void'
> > mapows.h:330: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'gmlNamespaceListObj'
> > mapows.h:331: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'void'
> > mapows.h:335: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'int'
> > mapows.h:346: error: expected ')' before '*' token
> > mapows.h:347: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'int'
> > mapows.h:358: error: expected declaration specifiers or '...' before
> > 'mapObj'
> > 'layerObj'
> > mapows.h:361: warning: 'enum MS_CONNECTION_TYPE' declared inside parameter
> > list
> > mapows.h:361: warning: its scope is only this definition or
> > declaration, which is probably not what you want
> > mapows.h:363: error: expected declaration specifiers or '...' before
> > 'mapObj'
> > 'layerObj'
> > mapows.h:364: error: expected declaration specifiers or '...' before
> > 'imageObj'
> > mapows.h:365: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'char'
> > mapows.h:380: error: expected ')' before '*' token
> > mapows.h:381: error: expected ')' before '*' token
> > mapows.h:384: error: expected ')' before '*' token
> > mapows.h:385: error: expected ')' before '*' token
> > mapows.h:401: error: expected declaration specifiers or '...' before
> > 'mapObj'
> > 'layerObj'
> > mapows.h:403: error: expected ')' before '*' token
> > mapows.h:404: error: expected ')' before '*' token
> > mapows.h:406: error: expected ')' before '*' token
> > mapows.h:407: error: expected ')' before '*' token
> > mapows.h:408: error: expected ')' before '*' token
> > mapows.h:409: error: expected ')' before '*' token
> > mapows.h:410: error: expected ')' before '*' token
> > mapows.h:411: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'char'
> > mapows.h:417: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'int'
> > mapows.h:418: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'int'
> > mapows.h:419: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'int'
> > mapows.h:420: error: expected '=', ',', ';', 'asm' or '__attribute__'
> > before 'int'
> > mapows.h:427: error: expected ')' before '*' token
> > mapows.h:435: error: expected ')' before '*' token
> > mapwfs11.c:35: error: expected declaration specifiers or '...' before
> > string constant
> > mapwfs11.c:35: warning: return type defaults to 'int'
> > mapwfs11.c: In function 'MS_CVSID':
> > mapwfs11.c:35: error: expected '{' at end of input
> > make: *** [mapwfs11.o] Error 1
> > On Wed, Mar 19, 2008 at 10:34 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>
> > wrote:
> >> Hi all: I've been beating my head against a configuration problem with Perl
> > MapScript today that stems from changes
> >> made for RFC 24. I have multiple version of mapscript installed and it's
> > fairly straight forward with Perl to do so, change
> >> 1 line in mapscript.i and one in Makefile.PL. Until now that is. In
> > plmodule.i there are references to mapscriptc and mapscript
> >> that must also be changed. I can do that and will also update the Perl
> > README to reflect that additional step. Before I do
> >> so I was wondering if there were a more portable way to write plmodule.i so
> > that it could automatically pick up on name
> >> change for the whole module. I don't how big a problem this is for other
> > languages. Thoughts?
> >> Steve
> >> _______________________________________________
> >> mapserver-dev mailing list
> >> mapserver-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
