[mapserver-dev] RFC 24 Changes to mapscript/perl/plmodule.i
Yewondwossen Assefa yassefa at dmsolutions.ca
Thu Mar 20 11:51:02 EDT 2008
Umberto Nicoletti wrote:
> On Thu, Mar 20, 2008 at 3:59 PM, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
>> Not sure on the build problems (not my fault for a change), so I won't update my
>>  source files for a while.
> I wasn't blaming you, Steve, just warning you that the patch is untested...
I am to blame for this :) Hopefully it is now fixed in svn. Let me know.
Later,
>>  Steve
>>  >>> On 3/20/2008 at 3:42 AM, in message
>>  <75b4b93e0803200142m57e1892l6c3d1f2aaa7a93a0 at mail.gmail.com>, "Umberto
>> Nicoletti" <umberto.nicoletti at gmail.com> wrote:
>>  > I was trying to help you out on this one (see attached patch), but I
>>  > can't compile mapserver:
>>  > unicoletti at ziggy ~/Workspace/eclipse/subversion/sandox/mapserver $make
>>  > gcc -c -O2 -fPIC -Wall     -DHAVE_VSNPRINTF -DNEED_STRLCAT
>>  >  -DUSE_WMS_SVR      -DUSE_GDAL  -DUSE_GEOS  -DUSE_THREAD -DUSE_PROJ
>>  > -DUSE_EPPL     -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
>>  > -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR
>>  > -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB     -I/usr/include
>>  >   -I/usr/include/gdal      -I/usr/include      mapwfs11.c -o
>>  > mapwfs11.o
>>  > In file included from mapwfs11.c:32:
>>  > mapows.h:31: error: expected specifier-qualifier-list before 'rectObj'
>>  > mapows.h:97: error: expected specifier-qualifier-list before 'hashTableObj'
>>  > mapows.h:116: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'int'
>>  > mapows.h:120: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'int'
>>  > mapows.h:121: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'int'
>>  > mapows.h:122: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'char'
>>  > mapows.h:123: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'char'
>>  > mapows.h:124: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'const'
>>  > mapows.h:125: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'const'
>>  > mapows.h:143: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'int'
>>  > mapows.h:144: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'const'
>>  > mapows.h:156: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'const'
>>  > mapows.h:158: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'int'
>>  > mapows.h:162: error: expected ')' before '*' token
>>  > mapows.h:166: error: expected ')' before '*' token
>>  > mapows.h:170: error: expected ')' before '*' token
>>  > mapows.h:174: error: expected ')' before '*' token
>>  > mapows.h:178: error: expected ')' before '*' token
>>  > mapows.h:190: error: expected ')' before '*' token
>>  > mapows.h:193: error: expected ')' before '*' token
>>  > mapows.h:196: error: expected ')' before '*' token
>>  > mapows.h:201: error: expected ')' before '*' token
>>  > mapows.h:206: error: expected ')' before '*' token
>>  > mapows.h:211: error: expected ')' before '*' token
>>  > mapows.h:214: error: expected ')' before '*' token
>>  > mapows.h:219: error: expected ')' before '*' token
>>  > mapows.h:222: error: expected ')' before '*' token
>>  > mapows.h:224: error: expected declaration specifiers or '...' before
>>  > 'mapObj'
>>  > mapows.h:225: error: expected ')' before '*' token
>>  > mapows.h:229: error: expected ')' before '*' token
>>  > mapows.h:230: error: expected ')' before '*' token
>>  > mapows.h:232: error: expected ')' before '*' token
>>  > mapows.h:321: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'int'
>>  > mapows.h:322: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'gmlItemListObj'
>>  > mapows.h:323: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'void'
>>  > mapows.h:324: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'gmlConstantListObj'
>>  > mapows.h:325: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'void'
>>  > mapows.h:326: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'gmlGeometryListObj'
>>  > mapows.h:327: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'void'
>>  > mapows.h:328: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'gmlGroupListObj'
>>  > mapows.h:329: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'void'
>>  > mapows.h:330: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'gmlNamespaceListObj'
>>  > mapows.h:331: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'void'
>>  > mapows.h:335: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'int'
>>  > mapows.h:346: error: expected ')' before '*' token
>>  > mapows.h:347: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'int'
>>  > mapows.h:358: error: expected declaration specifiers or '...' before
>>  > 'mapObj'
>>  > 'layerObj'
>>  > mapows.h:361: warning: 'enum MS_CONNECTION_TYPE' declared inside parameter
>>  > list
>>  > mapows.h:361: warning: its scope is only this definition or
>>  > declaration, which is probably not what you want
>>  > mapows.h:363: error: expected declaration specifiers or '...' before
>>  > 'mapObj'
>>  > 'layerObj'
>>  > mapows.h:364: error: expected declaration specifiers or '...' before
>>  > 'imageObj'
>>  > mapows.h:365: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'char'
>>  > mapows.h:380: error: expected ')' before '*' token
>>  > mapows.h:381: error: expected ')' before '*' token
>>  > mapows.h:384: error: expected ')' before '*' token
>>  > mapows.h:385: error: expected ')' before '*' token
>>  > mapows.h:401: error: expected declaration specifiers or '...' before
>>  > 'mapObj'
>>  > 'layerObj'
>>  > mapows.h:403: error: expected ')' before '*' token
>>  > mapows.h:404: error: expected ')' before '*' token
>>  > mapows.h:406: error: expected ')' before '*' token
>>  > mapows.h:407: error: expected ')' before '*' token
>>  > mapows.h:408: error: expected ')' before '*' token
>>  > mapows.h:409: error: expected ')' before '*' token
>>  > mapows.h:410: error: expected ')' before '*' token
>>  > mapows.h:411: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'char'
>>  > mapows.h:417: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'int'
>>  > mapows.h:418: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'int'
>>  > mapows.h:419: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'int'
>>  > mapows.h:420: error: expected '=', ',', ';', 'asm' or '__attribute__'
>>  > before 'int'
>>  > mapows.h:427: error: expected ')' before '*' token
>>  > mapows.h:435: error: expected ')' before '*' token
>>  > mapwfs11.c:35: error: expected declaration specifiers or '...' before
>>  > string constant
>>  > mapwfs11.c:35: warning: return type defaults to 'int'
>>  > mapwfs11.c: In function 'MS_CVSID':
>>  > mapwfs11.c:35: error: expected '{' at end of input
>>  > make: *** [mapwfs11.o] Error 1
>>  > On Wed, Mar 19, 2008 at 10:34 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>
>>  > wrote:
>>  >> Hi all: I've been beating my head against a configuration problem with Perl
>>  > MapScript today that stems from changes
>>  >>  made for RFC 24. I have multiple version of mapscript installed and it's
>>  > fairly straight forward with Perl to do so, change
>>  >>  1 line in mapscript.i and one in Makefile.PL. Until now that is. In
>>  > plmodule.i there are references to mapscriptc and mapscript
>>  >>  that must also be changed. I can do that and will also update the Perl
>>  > README to reflect that additional step. Before I do
>>  >>  so I was wondering if there were a more portable way to write plmodule.i so
>>  > that it could automatically pick up on name
>>  >>  change for the whole module. I don't how big a problem this is for other
>>  > languages. Thoughts?
>>  >>  Steve
>>  >>  _______________________________________________
>>  >>  mapserver-dev mailing list
>>  >>  mapserver-dev at lists.osgeo.org
>>  >>  http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
