[mapserver-dev] bug in WFS writer?
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Mar 20 16:12:31 EDT 2008
It's rare it hasn't been my problem so this is a nice twist. Thanks for the confirmation.
Steve
>>> "Bart van den Eijnden (OSGIS)" <bartvde at osgis.nl> 03/20/08 1:56 PM >>>
Steve,
you were absolutely right, it seems to be a client problem. Both
TatukGIS and ArcGIS make mistakes with these geometries, and Snowflake
and Gaia3 are the one that do it correctly. Although there is a slight
problem with Gaia3 for geometry no. 7.
See:
ArcGIS:
http://www.osgis.nl/download/umn/arcgis_kavels_gml.gif
Snowflake:
http://www.osgis.nl/download/umn/snowflake_kavels_gml.gif
Gaia3:
http://www.osgis.nl/download/umn/gaia3_kavels_gml.png
Sorry for the confusion!
Best regards,
Bart
Bart van den Eijnden (OSGIS) wrote:
> Okay, I found it already:
> http://trac.osgeo.org/mapserver/changeset/7164
> Best regards,
> Bart
>> Hey Steve,
>> Do you remember the bug number or changeset for that point-in-polygon
>> fix? It sounds like it could be the culprit indeed.
>> You're right it could be a problem in TatukGIS theoretically, but in
>> this case things were checked also in ArcGIS. So it would be strange
>> for 2 clients to have it wrong, though still possible.
>> Mapserver version: 4.10.2.
>> I haven't got the source data as yet (it's in Oracle Spatial), but
>> I'll try to get it.
>> Thanks.
>> Best regards,
>> Bart
>> Steve Lime wrote:
>>> Couple of questions:
>>> - how are you defining a "problem", based on TatukGIS's rendering
>>> or some other method? I'm not saying there isn't a problem but how
>>> do you know it's not a problem with the renderer?
>>> - do you have the source data (a shapefile?) available for testing?
>>> - what version of MapServer?
>>> I recall another bug recently similar to this. It had to do with the
>>> MapServer point-in-polygon being indeterminate when a point in one
>>> part is on a polygon edge. The function is key to determining inner
>>> and outer rings. I thought I fixed it though, at least in SVN. Since
>>> a legal polygon can only share 1 vertex with an edge I updated the
>>> code to check at least 2 and one more to break the tie if one
>>> happened to be on an edge. That worked in any testing I had done.
>>> Steve
>>>>>> On 3/19/2008 at 1:16 PM, in message <47E15866.2010407 at osgis.nl>,
>>>>>> "Bart van den
>>> Eijnden (OSGIS)" <bartvde at osgis.nl> wrote:
>>>> Hi list,
>>>> it seems Mapserver WFS has a problem with geometries having a
>>>> (common) point in them which touches the geometry itself. Mapserver
>>>> WMS seems to draw these polygons okay.
>>>> An example (look for instance at the second and third geometry):
>>>> WMS:
>>>> http://www.osgis.nl/download/umn/wms.png
>>>> WFS in TatukGIS (screendump):
>>>> http://www.osgis.nl/download/umn/tatuk.png
>>>> WFS xml file:
>>>> http://www.osgis.nl/download/umn/wfs.xml
>>>> Any ideas what could be causing this? Does this ring a bell to anyone?
>>>> Best regards,
>>>> Bart
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
