[mapserver-dev] RE: [UMN_MAPSERVER-DEV] Performance transparency
thomas bonfort thomas.bonfort at gmail.com
Tue Mar 25 04:12:36 EDT 2008
hi...
to get the source:
http://mapserver.gis.umn.edu/development/cvs/
to use opacity:
just add an OPACITY keyword in your style blocks (and remove the
opacity keyword from your layer ones). eg
STYLE
 COLOR 255 0 0
 OPACITY 50
END
for a semi-transparent polygon
thomas
On Tue, Mar 25, 2008 at 9:01 AM, Hallgren, Johan
<johan.hallgren at logica.com> wrote:
> Hello Thomas
>  I have to ask you;
>  -       How do I download the source I need? Do I have to download file by file, or could I download all files at once?
>  -       How do I activate the transparency, where in the mapfile?
>  /Johan
> ___________________________________
>  Johan Hallgren
>  Logica
>  Pelle Bergs backe 3
>  Box 1938, 791 19 Falun
>  Tel (och mobil): 023-547 46 (int: +46-2354746)
>  http://www.logica.se
>  -----Original Message-----
> From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
>  Sent: den 23 mars 2008 19:16
>  To: Hallgren, Johan
>  Cc: mapserver-dev at lists.osgeo.org
>  Subject: Re: [mapserver-dev] RE: [UMN_MAPSERVER-DEV] Performance transparency
> hi all,
>  code for AGG style level opacity is in the trunk (see
>  http://trac.osgeo.org/mapserver/ticket/1155 for limitations)
>  please report back if you see anything fishy going on...
>  On Fri, Mar 21, 2008 at 8:02 AM, Hallgren, Johan
>  >  Have you seen any performance differences? I don't know if you have followed my question but the problem we had was that when the size of the image increased the performance decreased more than expected (when using transparency). We had a raster map in background and rendered a polygon layer on top. As you probably understand we need to see thru the polygons. We want to have the polygon layer semi transparent, like 40% transparent or so.
>  >  Do you think you work will affect us?
>  yes, you should gain performance-wise by using style rather than layer
>  level opacity.
>  you gain:
>  * creation of a temporary gd image (that's image_height mallocs the
>  way gd works)
>  * merging of the temporary image onto the main mapserver image
>  (width*height blending operations)
>  * destroying of the temp image
>  cheers.
>  thomas
