[mapserver-dev] Standardized header: Miscellanous files with no
header
Normand Savard
nsavard at mapgears.com
Tue Mar 25 11:09:39 EDT 2008
All,
This is yet some other questions related to the standardized files
header. I found some files that do not have any header. I classified
them into five categories: build, swig interface, MapScript,
documentation and others. I propose a solution for each category but I
need your input before I take any action. I also listed these files by
directory where I found each one of them (see below).
Build:
Since configure.in has already a header, I propose to add the standard
header to these files with the copyright set to "Regents of the
University of Minnesota".
Swig interface:
Since most swig interface have already a header I suggest to do the same
for these files as well (see mapscript/swiginc). I need someone though
to decide to whom the copyright should go.
MapScript:
I suggest to add the standard headers to these files. Can someone
provide me the author and copyright of each one of these files?
Documentation:
I suggest to add the standard header to these files with the copyright
set to "Sean Gillies".
Others:
set to "Regents of the University of Minnesota" except for the
shp2mysql.pl file where the copyright is own by Attila Csipa.
Norm
Listing of files by directory
Build:
Root directory:
Makefile.in
Makefile.vc
aclolocal.m4
nmake.opt
mapscript/csharp:
Makefile.in
Makefile.vc
mapscript/perl:
Makefile.pl
mapscript/php3:
Makefile.vc
nmake.opt
mapscript/ruby:
extconf.rb
mapscript/tcl:
Makefile.in
Swing interface:
mapscript/java:
javamodule.i
mapscript/swiginc:
hashtable.i
owsrequest.i
rect.i
resultcache.i
MapScript:
mapscript/java/examples:
QueryByAttribute.java
QueryByAttributeUnicode.java
WxSTest.java
mapscript/java/tests/threadtest:
MapTest.java
MapThread.java
mapscript/php3:
phpinfo_mapscript.phtml
test_draw_legend_icon.phtml
test_draw_map.phtml
test_layer_mask.phtml
test_writeshape.phtml
mapscript/python/examples:
shpdumpl.py
shpinfo.py
mapscript/python/tests/timing:
clonemaps.py
drawshapes.py
mapscript/ruby/examples:
shp2img.rb
mapscript/tcl
mapscriptsupp.tcl
pkgIndex.tcl
mapscript/tcl/examples:
shpinfo.tcl
Documentation:
doc/mapscript.txt
doc/python.txt
Others:
root:
shp2mysql.pl
mapscript/php3:
hashtable_i.c
mapscript/python:
setup.py
mapscript/python/tests:
runalldoctests.py
mapscript/tcl/win:
setup.tcl
