[mapserver-dev] Re: [mapserver-users] Rendering of Static Text is
 different using gd	or AGG ?
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Tue May  6 11:19:39 EDT 2008
Jeff,
This is a good work around, but I think we need to ask the questions:
   What is the expected behavior?
   Is this a bug, should it be a bug?
   Should this behavior be documented?
   Should this be bugged for 5.2 freeze?
Clearly some code is translating the © for the GD renderer.
Adding cc: mapserver-dev, let me know If you want to to generate a bug
based on this and assign it to 5.2
-Steve W
Jeff McKenna wrote:
> What about using your operating system's character set?  For example on
> windows pressing ALT-0169 gives the copyright sign, and on MAC pressing
> OPTION-G.  So your mapfile snippet is:    TEXT "©"
> -jeff
> On 6-May-08, at 9:32 AM, Schönhammer, Herbert wrote:
>> Hi list,
>> Using* gd* the declaration "©"renders the "copyright"-Sign:
>> LAYER
>>   NAME "copyright"
>>   REQUIRES ..
>>   FEATURE
>>      POINTS
>>       3 10
>>      END
>>    END
>>   CLASS
>> *     TEXT "© xxx" *
>>     LABEL
>>       TYPE TRUETYPE
>>       FONT 'arial'
>>       SIZE 9
>>       POSITION cr
>>       COLOR 0 0 0
>>       OUTLINECOLOR  255 255 254
>>     END
>>   END
>> END # LAYER
>> But using agg, the text ""© xxx" is rendered in the map.
>> Please lokk at the examples !
>> Does anybody know,
>> how to render the html-code like done in gd ?
>> Does anybody know another way to render signs like "copyright"  with gd ?
>> Thanks very much
>> greetings
>> Herbert
>> <<gd-rendering.gif>> <<agg-rendering.gif>>
>> <gd-rendering.gif><agg-rendering.gif>_______________________________________________
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
