[mapserver-dev] More Performance
Paul Ramsey
pramsey at cleverelephant.ca
Mon May 12 15:21:39 EDT 2008
On Mon, May 12, 2008 at 12:07 PM, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> Thanks for the Shark tip, hadn't heard of that one.
FYI, on the Shark, to benchmark a single process, flip the mode from
"Everything" to "Process" and then if you scroll all the way to the
top of list of processes, you'll see "Launch" where you can fill in
the parameters of the process to run. No profiling flags required at
compile! Also, you can run in "Everything" mode and just pick the
process you want information for out of the list afterwards. I'll be
using that trick to profile the FCGI runs.
Fabulous tool. /Developer/Applications/Performance Tools/Shark
P.
