[mapserver-dev] setConfigOption is not working
Murty Maganti MMaganti at oriongis.com
Wed May 14 13:07:54 EDT 2008
Hi
I am trying to set a CONFIG option (using C# mapscript ) but it doesn't
seems to have any affect.
Here is the code
mapObj map = new mapObj("C:\\mymap.map");
map.setConfigOption("MS_PLUGIN_DIR", "C:\\my_plugins");
map.applyConfigOptions();
imageObj image=map.draw();
It is not loading the plug-in DLL. If I set this config option directly
in the map file, it works fine. Also, when I debug and check the value
of 'plugin_library' on layerObj, it does not contain the prefix of
plug-in directory.
Am I missing in steps here? Is this a known issue?
-Murty
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080514/7f62c93f/attachment.html
