[mapserver-dev] Re: [mapserver-users] testing mapserver large files
rendering improvements
Paul Ramsey
pramsey at cleverelephant.ca
Thu May 15 13:24:06 EDT 2008
Frank,
For a point-based tree, does every point end up in a node at max depth?
P.
On Thu, May 15, 2008 at 10:19 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> On Thu, May 15, 2008 at 10:15 AM, Bart van den Eijnden (OSGIS)
> <bartvde at osgis.nl> wrote:
>> 1) how will Mapserver know by default which depth to use for the index? On
>> large point shapefiles the default depth can result in negative performance.
> This says to me the heuristic needs to be smarter. I was just
> wondering that, when Frank said that the QIX can be larger than the
> SHP for points... that is not a given, perhaps the tree building code
> needs to be a little smarter
