[mapserver-dev] Re: [mapserver-users] testing mapserver large
files rendering improvements
Frank Warmerdam
warmerdam at pobox.com
Thu May 15 13:43:57 EDT 2008
Paul Ramsey wrote:
> Frank,
> For a point-based tree, does every point end up in a node at max depth?
Paul,
Yes. And the maximum depth is a heuristic as follows if not given
explicitly as an argument to shptree:
/* If no max depth was defined, try to select a reasonable one */
/* that implies approximately 8 shapes per node. */
if( tree->maxdepth == 0 ) {
int numnodes = 1;
while(numnodes*4 < shapefile->numshapes) {
tree->maxdepth += 1;
numnodes = numnodes * 2;
No long ago the default maxdepth was 16 and .qix files for small .shp files
were awfully large (deep).
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
