[mapserver-dev] Re: [mapserver-users] testing mapserver large
files rendering improvements
Paul Ramsey
pramsey at cleverelephant.ca
Thu May 15 15:42:31 EDT 2008
Why so few shapes per node? I was thinking about this walking downtown
and my internal guess was 128 would be a good number. How did you
come to 8?
P
On Thu, May 15, 2008 at 10:43 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Paul Ramsey wrote:
>> Frank,
>> For a point-based tree, does every point end up in a node at max depth?
> Paul,
> Yes. And the maximum depth is a heuristic as follows if not given
> explicitly as an argument to shptree:
> /* If no max depth was defined, try to select a reasonable one */
> /* that implies approximately 8 shapes per node. */
> if( tree->maxdepth == 0 ) {
> int numnodes = 1;
> while(numnodes*4 < shapefile->numshapes) {
> tree->maxdepth += 1;
> numnodes = numnodes * 2;
> No long ago the default maxdepth was 16 and .qix files for small .shp files
> were awfully large (deep).
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
