[mapserver-dev] Documentation,articles,etc
Roberto Urrutia evolutionex at hotmail.com
Tue May 20 04:18:40 EDT 2008
Thank you for answer my question.. Ok I try to do a specific question...
I would like to do a diagram about the internal operation of mapserver, but i  have some problems for identify some aspects . for example..
When I write this code in the .map
CONNECTIONTYPE postgis
NAME "river"
CONNECTION "user=db dbname=database host=robert"
DATA "geom from river"
What file (maybe files) analyze and link the information provided in the .map (CONNECTIONTYPE, CONNECTION,NAME and DATA) with the data (shp,jpg,etc  or  a database)?
Roberto
> Date: Mon, 19 May 2008 19:55:17 -0400
> From: warmerdam at pobox.com
> To: evolutionex at hotmail.com
> CC: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] Documentation,articles,etc
> Roberto Urrutia wrote:
> > Hello!
> > Sorry if i wrong to send this kind message to mapserver-developers,
> > but I decide to send this question , because I think is very probably
> > I am  looking for documentation,article, conference,etc. about the
> > algorithms used in the mapserver files?
> > specifically algorithms to support spatial database in mapserver?
> > I read the documents in the web page UMN mapserver, but only explain how
> > can i use the mapserver and not the algorithms used in the mapserver,the
> > operation algorithm or how can mapserver do to integrate different
> > spatial database.
> > I read each one of  the mapserver files and only have the developer name
> > and for what is used "x" file, but no more!
> > <javascript:onSubmitToolbarItemClicked('SendMessage','SendMessageLight.aspx?_ec=1&n=565437910');>
> > I hope anybody help me
> Roberto,
> Generally speaking there isn't much architectural documentation for MapServer.
> So you are reduced to "reading the source".  Much of the souce is written in
> a relatively straight forward way for a C programmer, and much of it has
> respectible inline comments.
> If you have fairly specific questions, you might also get some good info
> by asking here on the list.  But obviously your questions will need to be
> pretty focused if you hope someone will respond.
> Good luck,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
_________________________________________________________________
P.D. Checa las nuevas fotos de mi Space
http://home.services.spaces.live.com/
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080520/9e667cd9/attachment.html
