[mapserver-dev] nightly tarball build problems
Stephen Woodbridge
woodbri at swoodbridge.com
Sun May 25 17:51:41 EDT 2008
Changing TRUE to MS_TRUE seems to have fixed the compile problem. I
have not tested this path of code but it seems superficially like the
right thing to do.
-Steve
Stephen Woodbridge wrote:
> ./configure \
> --enable-ignore-missing-data \
> --with-httpd=/usr/sbin/httpd \
> --with-proj=/usr \
> --with-agg=../agg-2.4 \
> --with-gd \
> --with-freetype \
> --with-postgis \
> --without-tiff \
> --with-wmsclient \
> --with-php=../php-4.4.8 \
> --with-fribidi-config=yes
> make
> [snip]
> gcc -fPIC -O2 -fPIC -Wall -DCOMPILE_DL=1 -DPHP4
> -DNEED_NONBLOCKING_STDERR -DUSE_FRIBIDI -DUSE_WMS_LYR -DUSE_CURL
> -DUSE_WMS_SVR -DUSE_POSTGIS -DUSE_JPEG -DUSE_PROJ -DUSE_EPPL
> -DUSE_AGG -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
> -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR
> -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB
> -I/home/steve/work/mapserver-nightly -I/usr/local/include/fribidi
> -I/usr/include -I/usr/include
> -I/home/steve/work/mapserver-nightly/../agg-2.4/include
> -I/home/steve/work/mapserver-nightly/../agg-2.4/font_freetype
> -I/usr/include/freetype2 -I/usr/include
> -I/home/steve/work/mapserver-nightly/../php-4.4.8
> -I/home/steve/work/mapserver-nightly/../php-4.4.8/dl
> -I/home/steve/work/mapserver-nightly/../php-4.4.8/main
> -I/home/steve/work/mapserver-nightly/../php-4.4.8/Zend
> -I/home/steve/work/mapserver-nightly/../php-4.4.8/include
> -I/home/steve/work/mapserver-nightly/../php-4.4.8/TSRM -c -o
> mapscript_i.o mapscript_i.c
> mapscript_i.c: In function âmapObj_OWSDispatchâ:
> mapscript_i.c:335: error: âTRUEâ undeclared (first use in this function)
> mapscript_i.c:335: error: (Each undeclared identifier is reported only once
> mapscript_i.c:335: error: for each function it appears in.)
> make[1]: *** [mapscript_i.o] Error 1
> make[1]: Leaving directory
> `/home/steve/work/mapserver-nightly/mapscript/php3'
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
