[mapserver-dev] nightly tarball build problems
Daniel Morissette
dmorissette at mapgears.com
Mon May 26 08:38:53 EDT 2008
Yes, using MS_TRUE was the right fix. I believe Umberto caught and fixed
that in mapscript/swiging/map.i already on May 19th. (Not sure why the
nightly tarball is not updated though)
Daniel
Stephen Woodbridge wrote:
> Changing TRUE to MS_TRUE seems to have fixed the compile problem. I
> have not tested this path of code but it seems superficially like the
> right thing to do.
> -Steve
>> ./configure \
>> --enable-ignore-missing-data \
>> --with-httpd=/usr/sbin/httpd \
>> --with-proj=/usr \
>> --with-agg=../agg-2.4 \
>> --with-gd \
>> --with-freetype \
>> --with-postgis \
>> --without-tiff \
>> --with-wmsclient \
>> --with-php=../php-4.4.8 \
>> --with-fribidi-config=yes
>> make
>> [snip]
>> gcc -fPIC -O2 -fPIC -Wall -DCOMPILE_DL=1 -DPHP4
>> -DNEED_NONBLOCKING_STDERR -DUSE_FRIBIDI -DUSE_WMS_LYR -DUSE_CURL
>> -DUSE_WMS_SVR -DUSE_POSTGIS -DUSE_JPEG -DUSE_PROJ -DUSE_EPPL
>> -DUSE_AGG -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
>> -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR
>> -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB
>> -I/home/steve/work/mapserver-nightly -I/usr/local/include/fribidi
>> -I/usr/include -I/usr/include
>> -I/home/steve/work/mapserver-nightly/../agg-2.4/include
>> -I/home/steve/work/mapserver-nightly/../agg-2.4/font_freetype
>> -I/usr/include/freetype2 -I/usr/include
>> -I/home/steve/work/mapserver-nightly/../php-4.4.8
>> -I/home/steve/work/mapserver-nightly/../php-4.4.8/dl
>> -I/home/steve/work/mapserver-nightly/../php-4.4.8/main
>> -I/home/steve/work/mapserver-nightly/../php-4.4.8/Zend
>> -I/home/steve/work/mapserver-nightly/../php-4.4.8/include
>> -I/home/steve/work/mapserver-nightly/../php-4.4.8/TSRM -c -o
>> mapscript_i.o mapscript_i.c
>> mapscript_i.c: In function âmapObj_OWSDispatchâ:
>> mapscript_i.c:335: error: âTRUEâ undeclared (first use in this function)
>> mapscript_i.c:335: error: (Each undeclared identifier is reported only
>> once
>> mapscript_i.c:335: error: for each function it appears in.)
>> make[1]: *** [mapscript_i.o] Error 1
>> make[1]: Leaving directory
>> `/home/steve/work/mapserver-nightly/mapscript/php3'
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
