[mapserver-dev] known issue with Filter implementation?
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed May 28 11:12:29 EDT 2008
Bart,
The expressions out of the filters should place the brackets
properly. Quick tests on your filters using a postgis layer gives the
following expressions:
( (BEHEERDER= 'R') And ( (LENGTH> 10000) Or (BEHEERDER= 'P') ) )
( (BEHEERDER= 'P') Or ( (LENGTH> 10000) And (BEHEERDER= 'R') ) )
Not sure why you would get the same results. If you have specific data
tests, I will do additional tests.
Best Regards,
bartvde at osgis.nl wrote:
> Hi list,
> is it correct that Mapserver's Filter implementation does not deal with
> operator precedence?
> It seems to me Mapserver does not place extra brackets in the SQL query, so
> the standard SQL operator precedence (AND before OR etc.) prevails, and not
> the one specified in the ogc:Filter. Can anybody confirm this?
> For instance the following filters yield the same results with Mapserver
> 5.0.2, whereas they are different in the precedence:
> SQL: BEHEERDER = 'R' AND (LENGTH > 10000 OR BEHEERDER = 'P')
> Filter:
> <ogc:And>
> <ogc:PropertyIsEqualTo>
> <ogc:PropertyName>BEHEERDER</ogc:PropertyName>
> <ogc:Literal>R</ogc:Literal>
> </ogc:PropertyIsEqualTo>
> <ogc:Or>
> <ogc:PropertyIsGreaterThan>
> <ogc:PropertyName>LENGTH</ogc:PropertyName>
> <ogc:Literal>10000</ogc:Literal>
> </ogc:PropertyIsGreaterThan>
> <ogc:Literal>P</ogc:Literal>
> </ogc:Or>
> </ogc:And>
> versus:
> SQL: (BEHEERDER = 'R' AND LENGTH > 10000) OR BEHEERDER = 'P'
> Filter:
> <ogc:Or>
> <ogc:And>
> </ogc:And>
> </ogc:Or>
> TIA.
> Best regards,
> Bart
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
