[mapserver-dev] msProcessProjection() Error
Jeshua Lacock
jeshua at openosx.com
Thu May 29 16:12:48 EDT 2008
Greetings,
I am having difficulty testing our new build of MapServer 5.0.2,
Apache 2.2.8 and PHP 5.2.6 with the gmap46 demo. The CGI version works
fine with the Itasca demo.
We have two separate builds based on the identical software versions
and configurations for both Intel and PowerPC Macs. The Intel version
works flawlessly with the php gmap demo. With the PowerPC version I am
getting:
> Warning: [MapServer Error]: msProcessProjection(): in /Library/
> OpenOSX/apache2/htdocs/gmap/htdocs/gmap75.phtml on line 66
> Warning: Failed to open map file gmap75.map in /Library/OpenOSX/
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080529/b3c35859/corner_TL_LB.jpg
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080529/b3c35859/pixel.gif
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080529/b3c35859/corner_TR_LB.jpg
> Legend
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080529/b3c35859/icon_eye.gif
> Layer
> Fatal error: Call to a member function getlayerbyname() on a non-
> object in /Library/OpenOSX/apache2/htdocs/gmap/htdocs/gmap75.inc.php
> on line 525
The gmap and httpd.conf are indentical on both our Intel and PPC builds.
I did some searching and apparently it has something to do with proj.
I am using proj 4.6.0 and proj-datumgrid 1.3.
"epsg:42304" is defined in /Library/OpenOSX/grass/share/proj/
other.extra.
In the .map file, I tried setting:
CONFIG "PROJ_LIB" "/Library/OpenOSX/grass/share/proj/"
Which does not help. I am not sure if am using the directive correctly.
I have also tried rebuilding MapServer with the minimum of options
enabled with no luck. Proj and php both test out fine. I also tried
creating a minimum .map file, and I also get the same results with
any .map file I specify.
My phpinfo() shows:
> MapScript
> MapServer Version
> MapServer version 5.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=TIFF INPUT=EPPL7 INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> PHP MapScript Version
> ($Revision: 7251 $ $Date: 2008-01-08 09:04:53 -0800 (Tue, 08 Jan
> 2008) $)
Is there any way to get any more error logs? I looked in the Apache
error logs and I don't see anything helpful. I would be very grateful
for any tips/advice.
Any information to help point me in the right direction would be very
much appreciated, I am at a loss what to try next.
Thanks,
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 877.240.1364
