[mapserver-dev] mappostgis.c
Paul Ramsey
pramsey at cleverelephant.ca
Tue Nov 4 12:27:38 EST 2008
FYI, as threatened, I have updated the postgis driver in trunk rather
substantially. The binary cursor is gone, the SQL generation is a bit
more modular, much of the code duplication is removed, some memory
leaks are removed, I'm sure some others have been added (valgrinding
is still on the to-do list). In general the complexity is a lot lower
without the binary cursor, so it's all worthwhile.
I put some prototypes and structs in mappostgis.h, so I could bring
them into my unit tester more easily. The other thing on my "unit
testers wishlist" would be having the mapserver Makefile put things
like the INCLUDE paths and LIB flags and -D lists in a place where
other Makefiles could import them. For external apps making use of
libmapserver.a, it would be quite handy.
mappostgis.c has received light testing in map, query, nquery,
itemquery and itemnquery modes and seems to hold up OK. (Watching the
debug log during the nquery mode is especially horrifying, I had
forgotten the full extent of the inefficiency of the current set-up.)
If you happen to have PostGIS applications around, I would be
interested to hear if things still work "as expected" in trunk.
I did add in support for maxfeatures as well, but will probably have
to alter it a bit if we do an RFC on paging, since both query and map
mode are respecting maxfeatures as it stands.
P.
