[mapserver-dev] NODATA value problem
Frank Warmerdam
warmerdam at pobox.com
Mon Nov 10 10:18:17 EST 2008
Howard Butler wrote:
> Bart,
> I think this is the GDAL SDE driver's problem. I tabled nodata support
> in the SDE driver because at the time, Frank was working on the masking
> RFC, SDE supported masks, and I wanted to wait until that work was done
> before doing anything. The SDE raster driver needs to be updated to
> handle its nodata data, and ideally interact with GDAL's masking
> facilities.
Bart / Howard,
Note that MapServer does not support the masking facilities of GDAL at
this time.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
