[mapserver-dev] Documentation Updates
Howard Butler
hobu.inc at gmail.com
Mon Nov 24 14:57:33 EST 2008
On Nov 24, 2008, at 1:31 PM, Daniel Morissette wrote:
> Howard Butler wrote:
>> Here's some output that's basically a first run to give you an idea
>> where things are heading:
>> http://iowa.hobu.biz/msdocs/build/html/references/index.html
> I really like it!
> I presume we'd have a script that runs daily on the server to update
> the live docs from SVN?
Yes, similar to GDAL and Doxygen. We could even do branching (not
that GDAL does) ;)
> The nice thing with this approach is that the doc generation script
> can be in SVN too and I can easily update and preview changes
> locally just by rerunning the script on my machine. The end result
> is a tree of static HTML files, correct? So one can also zip up all
> the files and have a copy of the docs to browse offline, right? I
> luv it! :)
Yes. What was old is new :) The output is indeed static HTML (or PDF
from LaTeX or Windows HTMLHelp). A challenge yet to be addressed is
how to integrate this into Trac (if we should) and how far to do so if
we decide to. I still like OpenLayers' approach in this regard.
actually, it's 'make', but it runs Sphinx.
