[mapserver-dev] Documentation Updates
Howard Butler
hobu.inc at gmail.com
Mon Nov 24 17:25:49 EST 2008
On Nov 24, 2008, at 4:13 PM, Tamas Szekeres wrote:
> Howard,
> It looks really cool!
> Just looking into the docs I'm not sure how the docs should properly
> reference to each other.
Sphinx builds a giant dictionary when it makes the first pass through
the documents. It stuffs references to all headings and explicitly
defined references into this dictionary, and then you can use the
Sphinx ReST extension :ref: to refer to these anchors. You want to
keep them somewhat specific because you want them to act as global
(within the context of the documentation) identifiers. For example,
we have :ref:`mapfile` which points to the main mapfile reference,
or :ref:`LAYER` which points to the layer reference.
> It seems we should alter the previous approach in the documents,
> like for http://iowa.hobu.biz/msdocs/build/html/references/mapscript/dotnet_compile.html
> to avoid the warning.
That warning is because the win32 compilation doc hasn't been turned
into ReStructured text yet.
> Should we continue keep the doc along with the code in different
> directories or you're planning to set up a central repository
> somewhere?
> In my case the C# readme is the same as the compile doc exposed to
> the web site, so it would be reasonable to keep this doc in place.
I was deliberately pursuing a strategy of pulling docs *out* of the
places they were maintained in the source tree and into the
documentation tree. For example, I moved the main SWIG MapScript doc
to http://trac.osgeo.org/mapserver/browser/trunk/docs/references/mapscript/mapscript.txt
Things might continue to move around a bit more as we reorganize.
I moved the dotnet_compile doc out of mapscript/doc as well and into
the docs/references/mapscript directory.
> Best regards,
> Tamas
> PS: I'd apply for removing the trailing 't' char in my surname in
> the docs. My nickname (szekerest) contains just the abbreviation of
> 'tamas' in the end :-D This is because the Hungarians use reverse
> name ordering (surname firstname) by default, causing various kind
> of unexpected problems for us in various places ;-)
I suck. Please make any fixes to the docs as necessary :)
