[mapserver-dev] Buildbot down?
Tamas Szekeres
szekerest at gmail.com
Fri Nov 28 18:39:21 EST 2008
2008/11/29 Steve Lime <Steve.Lime at dnr.state.mn.us>
> Ok, no worries. Could someone validate that maplexer.c works for them? I
> had to rebuild on my Mac
> but that's typical. Just want to make sure it works on Linux ok. I
> generated on SuSE 9...
I've just tried on Windows with MSVC80(x86) and failed. See the output
below;
Best regards,
Tamas
Microsoft (R) Program Maintenance Utility Version 8.00.50727.762
Copyright (C) Microsoft Corporation. All rights reserved.
cl /nologo /Ox /MD /W3 /DDEBUG /EHsc /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_N
ONSTDC_NO_DEPRECATE -IE:\builds\release-1400\include -IE:\builds\regex-0.12
-DHA
VE_STRING_H -DREGEX_MALLOC -DNEED_STRCASECMP -DNEED_STRNCASECMP
-DNEED_STRLCAT -
DNEED_STRRSTR -DUSE_POSTGIS -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_JPEG
-DUSE_GD_P
NG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_GIF -DGD_HAS_GDIMAGEGIFPTR
-DUSE_GD_FT -
DGD_HAS_GETBITMAPFONT -DGD_HAS_FTEX_XSHOW -DUSE_OGR -DUSE_WMS_SVR
-DUSE_THREAD
-DUSE_WMS_LYR -DUSE_MING_FLASH -DIGNORE_MISSING_DATA
-DENABLE_STDERR_DEBUG -
DUSE_GDAL -DUSE_FASTCGI -DUSE_WFS_SVR -DUSE_WFS_LYR -DUSE_WCS_SVR
-DUSE_GD_A
NTIALIAS -DUSE_ICONV -DUSE_GEOS -DUSE_ZLIB -DUSE_SOS_SVR -DUSE_AGG
-DWIN
32 -D_WIN32 /c maprgbapng.c /Fomaprgbapng.obj
maprgbapng.c
/D_CRT_N
-DHA
-DNEED_STRLCAT -
-DUSE_GD_P
-DUSE_GD_FT -
-DUSE_THREAD
-DUSE_GD_A
-DWIN
32 -D_WIN32 /c mapbits.c /Fomapbits.obj
mapbits.c
/D_CRT_N
-DHA
-DNEED_STRLCAT -
-DUSE_GD_P
-DUSE_GD_FT -
-DUSE_THREAD
-DUSE_GD_A
-DWIN
32 -D_WIN32 /c maphash.c /Fomaphash.obj
maphash.c
/D_CRT_N
-DHA
-DNEED_STRLCAT -
-DUSE_GD_P
-DUSE_GD_FT -
-DUSE_THREAD
-DUSE_GD_A
-DWIN
32 -D_WIN32 /c mapshape.c /Fomapshape.obj
mapshape.c
/D_CRT_N
-DHA
-DNEED_STRLCAT -
-DUSE_GD_P
-DUSE_GD_FT -
-DUSE_THREAD
-DUSE_GD_A
-DWIN
32 -D_WIN32 /c mapxbase.c /Fomapxbase.obj
mapxbase.c
/D_CRT_N
-DHA
-DNEED_STRLCAT -
-DUSE_GD_P
-DUSE_GD_FT -
-DUSE_THREAD
-DUSE_GD_A
-DWIN
32 -D_WIN32 /c mapparser.c /Fomapparser.obj
mapparser.c
mapparser.c(1753) : warning C4102: 'yyerrlab1' : unreferenced label
/D_CRT_N
-DHA
-DNEED_STRLCAT -
-DUSE_GD_P
-DUSE_GD_FT -
-DUSE_THREAD
-DUSE_GD_A
-DWIN
32 -D_WIN32 /c maplexer.c /Fomaplexer.obj
maplexer.c
maplexer.l(68) : warning C4013: 'msyy_delete_buffer' undefined; assuming
extern
returning int
maplexer.l(71) : warning C4013: 'msyy_scan_string' undefined; assuming
extern re
turning int
maplexer.l(72) : error C2065: 'msyyin' : undeclared identifier
maplexer.l(72) : warning C4047: '=' : 'int' differs in levels of indirection
fro
m 'void *'
maplexer.l(92) : warning C4047: '=' : 'int' differs in levels of indirection
fro
m 'void *'
maplexer.l(387) : error C2065: 'msyytext' : undeclared identifier
maplexer.l(388) : warning C4047: 'function' : 'const char *' differs in
levels o
f indirection from 'int'
maplexer.l(388) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(388) : error C2109: subscript requires array or pointer type
maplexer.l(393) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(393) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(393) : error C2109: subscript requires array or pointer type
maplexer.l(394) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(394) : warning C4024: 'atof' : different types for formal and
actual
parameter 1
maplexer.l(400) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(400) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(400) : error C2109: subscript requires array or pointer type
maplexer.l(405) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(405) : warning C4024: 'atof' : different types for formal and
actual
parameter 1
maplexer.l(410) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(410) : warning C4024: 'atof' : different types for formal and
actual
parameter 1
maplexer.l(416) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(416) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(416) : error C2109: subscript requires array or pointer type
maplexer.l(418) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(418) : warning C4024: 'msParseTime' : different types for formal
and
actual parameter 1
maplexer.l(425) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(425) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(425) : error C2109: subscript requires array or pointer type
maplexer.l(431) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(431) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(431) : error C2109: subscript requires array or pointer type
maplexer.l(432) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(432) : warning C4024: 'strdup' : different types for formal and
actua
l parameter 1
maplexer.l(439) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(439) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(439) : error C2109: subscript requires array or pointer type
maplexer.l(445) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(445) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(445) : error C2109: subscript requires array or pointer type
maplexer.l(446) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(446) : warning C4024: 'strdup' : different types for formal and
actua
l parameter 1
maplexer.l(453) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(453) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(453) : error C2109: subscript requires array or pointer type
maplexer.l(459) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(459) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(459) : error C2109: subscript requires array or pointer type
maplexer.l(465) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(465) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(465) : error C2109: subscript requires array or pointer type
maplexer.l(474) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(474) : warning C4024: 'msBuildPath' : different types for formal
and
actual parameter 3
maplexer.l(474) : warning C4047: '=' : 'int' differs in levels of
indirection fr
om 'FILE *'
maplexer.l(480) : warning C4013: 'msyy_switch_to_buffer' undefined; assuming
ext
ern returning int
maplexer.l(480) : warning C4013: 'msyy_create_buffer' undefined; assuming
extern
returning int
maplexer.l(487) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(487) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(487) : error C2109: subscript requires array or pointer type
maplexer.l(493) : warning C4047: 'function' : 'const char *' differs in
levels o
maplexer.l(493) : warning C4024: 'strlen' : different types for formal and
actua
l parameter 1
maplexer.l(493) : error C2109: subscript requires array or pointer type
maplexer.l(495) : warning C4047: '=' : 'char *' differs in levels of
indirection
from 'int'
maplexer.l(511) : error C2109: subscript requires array or pointer type
maplexer.l(528) : warning C4047: 'initializing' : 'char *' differs in levels
of
maplexer.l(560) : error C2109: subscript requires array or pointer type
maplexer.l(560) : warning C4033: 'yylex' must return a value
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio
8\VC
\BIN\cl.EXE"' : return code '0x2'
Stop.
8\VC
\BIN\nmake.EXE"' : return code '0x2'
Stop.
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20081129/7599ac64/attachment-0001.html
