[mapserver-dev] IGNORE_MISSING_DATA
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Oct 9 16:30:43 EDT 2008
Paul Ramsey wrote:
> Submitted:
> http://svn.osgeo.org/mapserver/trunk/mapserver/rfc/ms-rfc-47.txt
Paul,
This looks good.
> Thoughts on the actual configuration mechanism, would be most appreciated.
I presume that you are asking how to get the compile time option to be
reflected in the code?
#ifdef IGNORE_MISSING_DATA
map->on_missing_data = MS_LOG;
#else
map->on_missing_data = MS_FAIL;
#endif
and something similar wherever the layer object os created and
initialized to its default values.
And in the configure script, --enable_ignore_missing_data just needs to add
-DIGNORE_MISSING_DATA to the list of defines passed to the complier.
-Steve W.
> P.
> On Wed, Oct 8, 2008 at 12:18 PM, Daniel Morissette
> <dmorissette at mapgears.com> wrote:
>> I too think that a RFC would be better to properly document the new
>> mechanism. It doesn't have to be long, but will help a lot in the future by
>> providing a place we can point users to.
>> Daniel
>> Steve Lime wrote:
>>> Maybe a real short one, just because it's related to core, and potentially
>>> hazardous portions
>>> of the code. Steve W. had some good suggestions and it's tough to tell
>>> where things are
>>> at with the ticket.
>>> Steve
>>>>>> On 10/3/2008 at 5:29 PM, in message
>>> <30fe546d0810031529i3012508cpedbeb6ba0ef90f3b at mail.gmail.com>, "Paul
>>> Ramsey"
>>> <pramsey at cleverelephant.ca> wrote:
>>>> I've moved this to an enhancement ticket. Do you feel this is RFC worthy?
>>>> http://trac.osgeo.org/mapserver/ticket/2785
>>>> Paul
>>>> On Thu, Oct 2, 2008 at 8:28 AM, Paul Ramsey <pramsey at cleverelephant.ca>
>>>> wrote:
>>>>> On Thu, Oct 2, 2008 at 5:42 AM, Jeff McKenna
>>>>> <jmckenna at gatewaygeomatics.com> wrote:
>>>>>>> Is there a reason that IGNORE_MISSING_DATA is a compile-time option? I
>>>>>>> have a client request to make it a run-time option, and also add the
>>>>>>> ability to run-time configure to error out in the case of WMS client
>>>>>>> layers that fail.
>>>>>> Yes I definitely agree with the need for this. I give a strong +1 for
>>>>>> this
>>>>>> potential RFC.
>>>>> Great, I'll write it up !
>>>>>> By the way Paul you got strong applause when the Sol Katz award for you
>>>>>> was
>>>>>> announced, and everyone liked your video. Congrats!
>>>>> Thanks Jeff!
>>>>> P.
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> Daniel Morissette
>> http://www.mapgears.com/
