[mapserver-dev] can i use some tool or ide to develop in mapserver?
Roberto Urrutia
evolutionex at hotmail.com
Sat Sep 6 21:52:42 EDT 2008
hi developers list
I would like to know your opinion, about which tool or IDE do you usually use for write and compile mapserver code ?
For example visual studio, Dev C++,builder c++ or any opensource such as kdevelop or only you use a linux console and a editor.
I need to know that, because I would like to develop some code for mapserver but it is very hard for me to work in linux console or editor,because I can not to add breakpoints for check line by line the variables or fix some error codes more easily..
Thank you..
_________________________________________________________________
P.D. Live Search tiene una sorpresa buenísima, chécala aquí.
http://www.ganabuscando.com/Default.aspx
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080907/e6e05a7f/attachment.html
