[mapserver-dev] phpmapscript whichShapes return code ?
Oliver Christen oliver.christen at camptocamp.com
Tue Sep 9 02:30:22 EDT 2008
Hi
using mapserver 5.0.2/php 5.2.5
im doing something like this:
       $map = ms_newmapobj("d:/msapps/gmap-ms40/htdocs/gmap75.map");
       $layer = $map->getLayerByName('road');
       $status = $layer->open();
       $status = $layer->whichShapes($map->extent);
       while ($shape = $layer->nextShape())
          echo $shape->index ."<br>\n";
       $layer->close();
when checking the $status value of the $layer->whichShapes($map->extent);
instructions I get the values 0 or 2.
0 seems to be equal to MS_SUCCESS
but 2 is definitively not equal to MS_FAILURE
I did that:
if ($status === MS_SUCCESS) {
    print "success"; // 0
}  else if ($status === MS_FAILURE) {
    print "failure";  // 1?
} else {
    print "unknown"; // 2
I never get "failure", I only get "success" or "unknown"
so, what is the meaning of a code 2 value?
thanks in advance
Oliver
