[mapserver-dev] building msplugin_mssql2008.dll
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Sep 16 15:40:30 EDT 2008
You're totally right Steve: Howard told me in IRC to commit the changes
so I did. (however I didn't file a ticket so I guess I get a big wrist
slap..ouch!)
sometimes I just lack confidence when i compare myself to all of u
MapServer developers. :) you guys are all so good! (if this is the
NHL I'm still making $300 a week down in the minors ha)
-jeff
Steve Lime wrote:
> Jeff: Don't you have svn write access? If so then I would think it entirely appropriate
> for you to commit the fix yourself (along with creating a trac ticket).
> Steve
>>>> On 9/16/2008 at 11:59 AM, in message <48CFE5FC.6030203 at gatewaygeomatics.com>,
> Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>> After much grief, I finally figured out why mssplugin_mssql2008.dll
>> would not build with MSVC 2003 or 2005 (using MapServer trunk):
>> Symptoms:
>> - building with the "plugins" target and setting the MSSQL2008 variable
>> in nmake.opt would produce no errors and no output whatsoever
>> Solution:
>> - line 222 of Makefile.vc is missing another "!ENDIF"
>> - remove lines 248 to 250 (in other words drop the final "!ELSE" statement)
>> Until a core mapserver developer goes to build this plugin this little
>> "fix" works for me.
