[mapserver-dev] building msplugin_mssql2008.dll
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Sep 16 14:18:23 EDT 2008
Jeff: Don't you have svn write access? If so then I would think it entirely appropriate
for you to commit the fix yourself (along with creating a trac ticket).
Steve
>>> On 9/16/2008 at 11:59 AM, in message <48CFE5FC.6030203 at gatewaygeomatics.com>,
Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> After much grief, I finally figured out why mssplugin_mssql2008.dll
> would not build with MSVC 2003 or 2005 (using MapServer trunk):
> Symptoms:
> - building with the "plugins" target and setting the MSSQL2008 variable
> in nmake.opt would produce no errors and no output whatsoever
> Solution:
> - line 222 of Makefile.vc is missing another "!ENDIF"
> - remove lines 248 to 250 (in other words drop the final "!ELSE" statement)
> Until a core mapserver developer goes to build this plugin this little
> "fix" works for me.
