[mapserver-dev] Collaborators wanted for RFC-45
Paul Spencer
pspencer at dmsolutions.ca
Thu Sep 18 07:44:33 EDT 2008
Steve, I'm not sure this is directly related to what you are asking,
but I thought I would bring it up in the context of improved
labeling. I really like the PROCESSING=LABEL_NO_CLIP feature but I
have come across a couple of limitations that cause labels to get cut
off in adjacent tiles. I'm not sure if it is fixable but if it is, it
would be really nice to get it in to 5.4. I have two specific cases
which cause problems right now.
1) if you have a polygon feature near the edge of a tile and it gets
labelled such that the label is outside the polygon (this happens for
smaller polygons with longer labels), and the polygon does not extend
into the adjacent tile, the rest of the label doesn't get drawn.
2) You have a polygon feature that crosses a tile boundary and another
polygon feature wholly in the adjacent tile. The first feature's label
is drawn in the first tile but in the second tile the label of the
second feature takes priority and the rest of the first feature's
label isn't drawn, even though it's polygon extends into the second
tile.
I'm not sure if there is an intelligent way to fix this. The only
thing I can think of is to expand the extent for which features are
collected to be considered for labeling, which would have at least a
small performance impact and possibly a large one. Perhaps this could
be done as some kind of buffer? The size of the buffer doesn't need
to be large in the vertical axis, more-or-less the spatial equivalent
of the height of a label (about 12 pixels perhaps) although even less
would probably yield excellent results. Horizontally, its a bit more
challenging because it depends on the size of the longest label I
think, but that should be something that can be tweaked for any given
map.
Do you think that it would be possible to specify a per-layer
horizontal and vertical buffer in pixels for expanding the extent when
collecting shapes for labeling?
Cheers
Paul
On 17-Sep-08, at 10:39 PM, Steve Lime wrote:
> Hi all: Version 5.4 will likely see a rash of cartographic
> improvements (symbols, labels, etc...) and I've stared an RFC to
> capture them as a whole (instead of 10 little ones). I invite anyone
> with an interest in this stuff to please take a peek and join in the
> the development of this one. The first tangible outcomes will likely
> be doubles for styleObj SIZE/WIDTH and the label placement
> improvements.
> See http://mapserver.gis.umn.edu/development/rfc/ms-rfc-45, just
> above Hobu's anti-Plone rant. ;-)
> Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://www.dmsolutions.ca/
