[mapserver-dev] AGG/PNG && QUANTIZE_FORCE && --with-experimental-png => bad IE6 rendering
David Fuhry dfuhry at acm.org
Thu Sep 18 11:24:59 EDT 2008
I generated the attached tile.png with AGG/PNG and QUANTIZE_FORCE=ON,
using a --with-experimental-png build of mapserver (to get PNG-8
transparency).  It's an 8-bit PNG image with a transparent background.
The image looks great in every browser except IE6, which only renders
certain pieces of lines (see other attached image).  Is this a known
problem?
I've tried INTERLACE=OFF with no success.  Changing the driver to GD/PNG
works, but of course I don't get the AGG smoothness.  There is no
AGG/GIF driver yet, so that's not an option.  And finally, a 24-bit PNG
is not an option since IE<7 doesn't support alpha transparency.
I'm now beginning to wonder if the misrendering is due to alpha
transparency (not supported by IE6-) on the 8-bit image.  I didn't think
that 8-bit PNGs supported alpha transparency (GIFs don't) but according
to this article:
http://www.sitepoint.com/blogs/2007/09/18/png8-the-clear-winner/ indexed
PNGs can store alpha channel values for one *or more* palette entries.
If this is the case, then a welcome FORMATOPTION might be
QUANTIZE_ROUND_TRANSPARENCY which would round palette entries'
transparency up to 100 or down to 0.  Hmmm... but then (since there's no
background color) AGG smoothness would be lost, and one might as well
use GD/PNG, so maybe not.
I'll look into the IE htc (css behavior: ...) hack as a possible
solution.  Better suggestions appreciated.
Thanks,
Dave Fuhry
OUTPUTFORMAT
   NAME "AGG_PNG8"
   DRIVER AGG/PNG
   IMAGEMODE RGB
   FORMATOPTION "QUANTIZE_FORCE=ON"
   FORMATOPTION "QUANTIZE_COLORS=256"
   FORMATOPTION "INTERLACE=OFF"
   TRANSPARENT ON
END
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080918/a45e3723/tile-0001.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080918/a45e3723/tile_as_rendered_in_ie6-0001.png
