[mapserver-dev] mapscript_csharp: using STYLEITEM "AUTO"
Prakash Tilhoo
prakashtilhoo at astuntechnology.com
Thu Apr 16 13:19:10 EDT 2009
Tamas,
Thank you very much for your usual reply.
When I do classObj cls = new classObj(layer), I get default Label style
sections created in map file.
1) Example 1
STYLEITEM "AUTO"
CLASS
NAME "Elevation Poly 5"
END
END # Layer
I understand that cls.name <http://cls.name> = "Elevation Poly 5"; will
give the above, along with other things mentioned above.
2) Example 2
STYLEITEM "AUTO"
CLASS
color 255 255 255
END
END # Layer
Doing
styleObj style = new styleObj(cls);
style.setRGB(255,255,255);
will give something like below in map file:
STYLEITEM "AUTO"
CLASS
Style
color 255 255 255
END
END
END # Layer
QUESTION:
Will these additional entries in the map file affect the 'mapserver'
rendering or will it be same as it would be with two plain above examples ?
Tamas Szekeres wrote:
> Hi,
> You can do something like:
> layer.styleitem = "AUTO";
> classObj cls = new classObj(layer);
> Best regards,
> Tamas
> 2009/4/16 prak <prakashtilhoo at astuntechnology.com
> <mailto:prakashtilhoo at astuntechnology.com>>
> Hello everyone,
> I am using mapscript_csharp to provide user with ability to edit
> map file.
> However, for a layer with setting 'STYLEITEM "AUTO"', there is no
> 'classobj', but can have entries in map file that look like;
> 1) Example 1
> STYLEITEM "AUTO"
> CLASS
> END
> END # Layer
> 2) Example 2
> STYLEITEM "AUTO"
> CLASS
> color 255 255 255
> END
> END # Layer
> Using map script, if I do classObj ocls = new classObj(layerObj),
> the map file will get a 'class' section, but then how can entries
> like in above examples be 'insertted' using mapscript_csharp ?
> Look forward to your usual and kind advice and help.
> Kind Regards
> http://n2.nabble.com/mapscript_csharp%3A-using-STYLEITEM-%22AUTO%22-tp2642811p2642811.html
> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Regards
Prakash Tilhoo
Astun Technology Ltd
Cadogan House, 4-6 High Street
Epsom, Surrey, KT19 8AD, UK
t:+44 1372 440 143
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090416/e173f442/attachment.html
