[mapserver-dev] mapscript_csharp: using STYLEITEM "AUTO"
Tamas Szekeres szekerest at gmail.com
Thu Apr 16 11:58:16 EDT 2009
You can do something like:
layer.styleitem = "AUTO";
classObj cls = new classObj(layer);
cls.name = "Elevation Poly 5";
styleObj style = new styleObj(cls);
style.setRGB(255,255,255);
Best regards,
Tamas
2009/4/16 prak <prakashtilhoo at astuntechnology.com>
> Hello everyone,
> I am using mapscript_csharp to provide user with ability to edit map file.
> However, for a layer with setting 'STYLEITEM "AUTO"', there is no
> 'classobj', but can have entries in map file that look like;
> 1) Example 1
> STYLEITEM "AUTO"
> CLASS
>        NAME "Elevation Poly 5"
> END
> END # Layer
> 2) Example 2
> STYLEITEM "AUTO"
> CLASS
>     color 255 255 255
> END
> END # Layer
> Using map script, if I do classObj ocls = new classObj(layerObj), the map
> file will get a 'class' section, but then how can entries like in above
> examples be 'insertted' using  mapscript_csharp ?
> Look forward to your usual and kind advice and help.
> Kind Regards
> http://n2.nabble.com/mapscript_csharp%3A-using-STYLEITEM-%22AUTO%22-tp2642811p2642811.html
> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090416/817df251/attachment.html
